Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Machines running Mach Software
Machines running Mach Software Discuss your set-up and experiences running your machine using Mach software here.
Old 04-01-2007, 10:19 PM
thesaent14 is on a distinguished road
problem with my z axis on mach3
can any one tell me why when i start to cut any part my z go all the way down to the last part i set up my g code on lazycam and still go dip i have not cut anyting yet any of my trys are bad i get a dip holl in the part
Old 04-02-2007, 09:10 PM
well after waching some of the videos and i really don't know how it worcks on the mesuments for the lazycam dose it worck on mm or inches what i have to do the ticnes of the matirial is 1/4
Old 04-02-2007, 09:12 PM
ger21's Avatar
Can you post 20-30 lines of your g-code?
Old 04-02-2007, 09:25 PM
N5 (File defeuser 10333 )
N10 (Default Mill Post)
N15 (File Posted in Mill Mode)
N20 (Monday, April 02, 2007)
N25 G90 G80 G40 G91.1
N30 G0 Z0.0000
N35 X33.5026 Y36.0595
N40 Z0.1000
N45 M3
N50 G1 Z6.3000 F3.20
N55 X33.1585 Y35.5989 F100.00
N60 G2 X43.5485 Y40.8064 I3.8900 J5.2075
N65 X33.1585 Y35.5989 I-6.5000 J0.0000
N70 G1 X33.5026 Y36.0595
N75 G0 Z0.0000
N80 X57.1395 Y56.5732
N85 Z0.1000
N90 G1 Z6.3000 F3.20
N95 X56.7954 Y56.1126 F100.00
N100 G2 X88.7646 Y72.1356 I11.9692 J16.0231
N105 X56.7954 Y56.1126 I-20.0000 J0.0000
N110 G1 X57.1395 Y56.5732
N115 G0 Z0.0000
N120 X57.1395 Y116.6209
N125 Z0.1000
N130 G1 Z6.3000 F3.20
N135 X56.7954 Y116.1602 F100.00
N140 G2 X88.7646 Y132.1833 I11.9692 J16.0231
N145 X56.7954 Y116.1602 I-20.0000 J0.0000
N150 G1 X57.1395 Y116.6209
N155 G0 Z0.0000
N160 X33.1295 Y158.0198
N165 Z0.1000
N170 G1 Z6.3000 F3.20
N175 X32.7854 Y157.5591 F100.00
N180 G2 X43.1754 Y162.7666 I3.8900 J5.2075
N185 X32.7854 Y157.5591 I-6.5000 J0.0000
N190 G1 X33.1295 Y158.0198
N195 G0 Z0.0000
N200 X122.0641 Y116.6209
N205 Z0.1000
N210 G1 Z6.3000 F3.20
N215 X121.7200 Y116.1602 F100.00
N220 G2 X153.6892 Y132.1833 I11.9692 J16.0231
N225 X121.7200 Y116.1602 I-20.0000 J0.0000
N230 G1 X122.0641 Y116.6209
N235 G0 Z0.0000
N240 X158.1280 Y159.8846
N245 Z0.1000
N250 G1 Z6.3000 F3.20
Old 04-02-2007, 09:38 PM
ger21's Avatar
Whatever units you draw your part with in your CAD program is what LazyCAM should use. Set the cutting depth to a negative number, -.25 to cut 1/4" deep. Before running the code, set the top of your part to be Z = 0.
Old 04-02-2007, 10:18 PM
well thats most of my confecion i was drawing in inch and still go dip
Old 04-03-2007, 06:32 AM
ger21's Avatar
Can you post your .dxf file?
Old 04-03-2007, 07:41 PM
dxf003
here it is
Old 04-03-2007, 08:10 PM
ger21's Avatar
Do you have it figured out now? Your drawing is in inches, so you enter the info in LazyCAM in inches
Old 04-03-2007, 08:24 PM
so many Q? not know how to make them i do it in inc or mm i don't know why still doing it i don't know whats wrong with my machine i saw the videos on the mach3 web page and i have all the setups like is supposed to be and still do the same is there a way i can speak to some one and see what i am doing wrong
thanks for the replays
manny
  #11   Ban this user!
Old 04-03-2007, 09:29 PM
KKutt is on a distinguished road
G0z0
Might check to see if your clearance height is set in negative instead of positive or Vise-versa. Just a guess. looks like you are raipiding to a Z 0 then machining above that.
  #12   Ban this user!
Old 04-03-2007, 09:43 PM
thats somting ells i don't know whats what on this + or - i don't know how the machine is suppost to be
Mach3 with Taig Motor Feed Rate Problem alt255 Taig Mills & Lathes 8 12-13-2006 01:50 PM
Mach2/Mach3 installation problem (laptop) xyz100 Mach Software (ArtSoft software) 3 07-25-2006 08:56 AM
Mach3 converting dxf files problem randyf1965 DIY-CNC Router Table Machines 7 04-18-2006 11:28 PM
Mach3 limit switch problem on Ref Home originator Mach Software (ArtSoft software) 1 03-13-2006 08:02 AM
Mach3 Mill Pausing Problem Lionclaw Mach Mill 6 11-14-2005 12:05 PM
