Results 1 to 7 of 7
Thread: inputs outputs
    Feb 2005
    inputs outputs
    I first had my main computer setup running mach 3. My computer using xp pro. Now I put my cnc in the garage and bought a laptop for it using a wireless router. My laptop is running 2000 professional. Now none of my exact settings will work with the cnc ???
    Mar 2003
    Shelby Twp, MI....USA
    Are you sure the laptop is capable of running Mach3?
    Feb 2005
    The laptop is a dell 1ghz and 256mb of ram. Running 2000 pro. Why wouldnt it be capable of running mach 3?
    Registered WayneHill's Avatar
    Mar 2004
    Michigan
    Check the BIOS setting of the parallel port.
    Wayne Hill
    Mar 2003
    Run the drivertest.exe in the Mach3 folder. Make sure it gives good results. Lots of laptops won't run well, for a variety of reasons. Power management being one reason, 3.3V parallel ports being another.
    Feb 2005
    ok I dont have a problem switching out computers, I just thought being mobile would be the way to go out in my garage. I didnt realize problems like that existed. Let me swap out computers and I will let you guys know.
    Feb 2005
    I can still get movement and everything but the settings I put such as my inputs to make motors turn in correct direction are messed up and only wants to go in one direction
    1. E-stop and enable outputs
      By Drew in forum Machines running Mach Software
      Last Post: 06-01-2009, 07:18 AM
    2. Inputs/Outputs
      By UKRobotics in forum General Electronics Discussion
      Last Post: 08-02-2006, 10:52 PM
    3. Opto 22 / ICM outputs not working
      By mzartop6 in forum CamSoft Products
      Last Post: 01-27-2006, 11:35 PM
    4. R20x0 encoder outputs?
      By mecheng10 in forum Servo Drives
      Last Post: 10-05-2005, 10:11 PM
    5. Encoder output into 2 different inputs?
      By murphy625 in forum Servo Motors and Drives
      Last Post: 03-23-2005, 10:36 AM
