Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Machines running Mach Software
Machines running Mach Software Discuss your set-up and experiences running your machine using Mach software here.
Old 03-13-2007, 07:53 PM
eloid is on a distinguished road
G-Rex & mach3
does mach3 support G-Rex G100?
Old 03-13-2007, 08:36 PM
ger21's Avatar
The Mach3 plugin is being developed right now. There was about a 1 year delay while new firmware was being written for the G100, but the plugin is expected to be completed in the next 2-3 months. You can download beta versions now.
Old 03-13-2007, 08:41 PM
ger21's Avatar
I also posted this the other day from Art.
http://www.cnczone.com/forums/showpo...31&postcount=6
Old 03-13-2007, 08:47 PM
G-Rex G100
so with the grex G-Rex G100 G-Rex G101 you can the bob board?
Old 03-14-2007, 06:00 PM
Moderator
JerryFlyGuy is on a distinguished road
Yes, the G100 replaces the BOB, it also replaces any question's one might have w/ the robustness of timing w/in windows. It also has 16 inputs, 16 outputs and 4 anologe in 4 anologe outputs as well as 6 limit inputs 6 encoder inputs and the needed step direction connections for 6 axis. It will export step direction signal's up to 4 Mhz per axis and will accept up to 1Mhz input on the encoder side [per axis] In comparison, Mach3 will only send out 45Khz of step/direction pulses.
The G100 will do everything that two breakout boards will do, and do it better, faster, and smoother. It also cost's 2-3x as much as a standard BOB.
I'm using one w/ the current Beta Plug and it run's great! There are a couple tweak's to get done before its full release.. however I'm really impressed with how well it run's even w/ just a Beta Plugin.
Jerry
JerryFlyGuy
The more I know... the more I realize I don't
Old 03-14-2007, 06:07 PM
vacpress is on a distinguished road
jerry
I am very interested in this product. Any chance you could write a bit of a review? Maybe discuss your machine, application, and the results the G100 allows?
Ignore me if this seems demanding!
R
Design & Development
My Portfolio: www.robertguyser.com | CAD Blog I Contribute to: http://www.jeffcad.info
Old 03-14-2007, 07:56 PM
Moderator
I'd love to.. if I could find the time... my writing isn't probably the best either as I tend to ramble..
We'll see maybe I'll get time at some point.. its probably not worth the effort until it's "offically" released anyway..
Jerry
JerryFlyGuy
Old 03-14-2007, 11:50 PM
Jerry
true, they probably have some documentation planned.. videos, etc.. to get it up with the rest of artsoft documentation...
what you mentioned allready is more information than i saw since before it was made..
Mach3 0-5V to 12-24V ?? jimmychand Mach Software (ArtSoft software) 2 01-11-2007 06:14 AM
Microkinetics and Mach3 skimpro Mach Software (ArtSoft software) 1 12-18-2006 01:16 PM
Mach3 and USB mikep608 Mach Mill 3 08-09-2006 12:56 AM
mach3 please help nymachinist CNCzone Club House 1 01-31-2006 06:59 AM
Using Mach3 with DeskCNC WarrenW Mach Software (ArtSoft software) 18 01-04-2006 02:42 PM
