Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Machines running Mach Software
Machines running Mach Software Discuss your set-up and experiences running your machine using Mach software here.
Old 03-11-2007, 02:20 PM
wddanie is on a distinguished road
hw allow Mach and Labview to drive a mill?
Can somone suggest hw to allow either Mach or Labview to drive the same milling machine?
I am planning a mill retrofit and want to drive the mill for metal
cutting using Mach. I also have inspection needs for a big positioner
to move a sensor over a part, so it would be nice to use the mill for
that as well, but I want to drive it from Labview for that task so that
the data logging from the sensor can be easily coordinated with
motion.
I thought I saw a post a while back about someone writing Labview VIs for the Gecko G-Rex, but I cannot find any confirmation of this now. I'm open to any hw to do this, so can you suggest any hw that will work with both software approaches.
Thanks in advance,
Doug Danielson
Atlanta
Old 03-11-2007, 03:23 PM
Gold Member
InspirationTool is on a distinguished road
LabView should be able to drive the parallel port, so that would work for a parallel port based driver.
-Jeff
Old 03-12-2007, 09:36 PM
I have not been able to find a Labview VI that sends the step and dir pulses out the parallel port. I hope I can find one rather than having to make my own.
I thought I read in the past about someone writing a VI to drive the G-Rex from LV, but I have not found it yet.
Thanks for your suggestion,
Doug Danielson
Old 03-28-2007, 01:16 PM
PoppaBear10's Avatar
PoppaBear10 is on a distinguished road
do it the easy way,
use your in a "Scanning" tool path, (create it in your cam as a surfacing operation with back and fourth raster moves).
From Lab view once you up and ready to scan, press a button in the view that sends out a signal by what ever means, (i.e. modbus, or USB I/O, or what ever). In the Macro pump on mach have it running a If then statement, that when IsActive(INPUT1) or what ever comes on, then it does a DoOEMButton cycle start. Your scanning program starts running, and your inspection equipment starts putting in data into your Lab view app.
scott
Direct Drive Vs Belt Drive for a Mill/Drill Retrofit? pfeist General Metal Working Machines 11 02-13-2012 02:12 AM
VIs to allow Labview to drive the G-Rex? wddanie Gecko Drives 0 03-11-2007 02:08 PM
Confused: Mach Turn, Mach Mill, Mach 2/3 ? CanSir Mach Software (ArtSoft software) 5 02-16-2007 04:41 AM
RS 232 communication using LABview for modem nabihahismail Computers and Networking 0 02-12-2007 04:54 AM
will my drive work with mach 3 Fabric8r Mach Mill 1 02-01-2006 05:46 AM
