Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Machines running Mach Software
Machines running Mach Software Discuss your set-up and experiences running your machine using Mach software here.
Old 03-11-2007, 02:01 PM
mariano_mdf is on a distinguished road
Problem with CV mode
Hello,
I'm trying to mechanize a complex geometry composed for hundreds of small lines (G01 codes). I want the machine to move smooth, (since de lines are actually part of continuos bezier curve). So, i put the G64 code at first, in order to set the CV mode.
But, it does't work as i expected. The machine did move smoth 10 or 15 movement, then stop, and start, makes another 10 or 15 movements, stop and start. The movement is smother than in exact stop mode, but yet it is not smoth as i need. It seems like the program only read 10 or 15 gcode lines ahead. I tryed all the opcions : angular discrimination, etc etc. Any suggest? I am using mach2
Thanks in advance and sorry about my english.
Mariano
Old 03-11-2007, 02:09 PM
ger21's Avatar
Not sure about Mach2, but Mach3 has a look ahead # of lines setting. You might want to try Mach3.
Old 03-11-2007, 02:28 PM
look ahead
Thanks for answer. I didn't find any look ahead option on the mach 2 configuration. So i will try mach3. I'll post what happened then.
Mariano
dro in manual mode... triberman Mach Software (ArtSoft software) 19 03-02-2011 01:24 PM
Phase mode without controller Alex101 TurboCNC 1 06-12-2007 05:53 AM
X in demo mode mdlmkr Mastercam 2 10-28-2005 08:53 AM
EZ Trak Plus - G code mode? zcases Bridgeport and Hardinge Mills 4 05-07-2005 10:26 PM
Fanuc tape mode mroy0404 Fanuc 2 03-17-2005 03:15 PM
