Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Machines running Mach Software
Machines running Mach Software Discuss your set-up and experiences running your machine using Mach software here.
Old 03-10-2007, 10:52 AM
Jenn is on a distinguished road
Question Motors
Hi! Question is: Why do the motors run forward and reverse with Quick Step software but only forward with Mach?
Signed,
Very confused
Any help would be greatly appreciated!!
Old 03-10-2007, 10:56 AM
ger21's Avatar
What drives are you using, and can you post a screenshot of your ports and pins page?
Old 03-10-2007, 12:56 PM
Hi. K159 drivers. At this point I am not at the shop but George is. We do not have a photo at this time, will work on that, he doesnt have his camera w/him. We are using pins:2&3,5&6. We are using a demo version, do you think that matters? Thank you.
Old 03-10-2007, 01:00 PM
It runs both ways in the demo version "Mach2". Weird
Old 03-10-2007, 04:34 PM
ger21's Avatar
You probably have a setting wrong.
Old 03-11-2007, 08:32 AM
Cool
It is really strange that Mach2 & 3 would have different settings, but that is how it goes!! I will go through all the settings again. Thank you so much for your time Gerry, I really, really appreciate it.
Jenn
Old 03-11-2007, 08:54 AM
ger21's Avatar
They don't, really. The only motor related things that are really different is the motor tuning, as it's in different units in Mach3. Ports and pins should be the same. Make sure you have the correct port assigned to each pin.
425 oz in motors a bit hot oddatwl Xylotex 5 07-26-2008 10:12 PM
What can I do with this motors? tante DIY-CNC Router Table Machines 3 10-21-2006 02:19 PM
Hot Motors WJHildreth CNC Wood Router Project Log 4 05-28-2006 03:59 PM
What motors can I get from a car gv71 General Electronics Discussion 5 07-13-2004 08:32 AM
33 Oz/in Motors Are They Enough chadwiggan Machine Problems, Solutions , Wireless DNC, serial port 4 01-10-2004 05:09 PM
