Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Machines running Mach Software
Machines running Mach Software Discuss your set-up and experiences running your machine using Mach software here.
Old 03-07-2007, 02:21 PM
cookja01 is on a distinguished road
Motor Tuning
I just finished wiring up my breaker board. At first both motors would not turn, although one would feel like it was trying to pulse a little. I am trying to run a 1850oz/in and a 1150oz/in stepper with gecko G201's. I then switched the motors around, now each running on the oposite driver. The same thing happened with the other motor now trying to move. I then went into Mach3 and tuned the motors. Now I can get one motor to turn (fairly fast) but the other one still does not move. I think that the problem is in one of the drivers. The motor that will not turn has power going to it because I can not turn the motor by hand. I am lost and could rerally use some help.
Old 03-07-2007, 02:27 PM
Konstantin's Avatar
Konstantin is on a distinguished road
Switch the wiring of the working motor DRIVE to the not working pins to rule out a BOB cold solder or something.
Konstantin.
HELP.....Motor Tuning Question NardisAmps Machines running Mach Software 7 02-26-2007 04:20 PM
Motor tuning under Mach3 BAustin Industrial Hobbies (Support forum) 3 12-23-2006 11:23 PM
Help needed for mach 3 motor tuning Grandad DIY-CNC Router Table Machines 18 04-25-2006 05:54 PM
Bosch Tuning, Sem Motor Brushes machintek Bridgeport and Hardinge Mills 1 11-17-2005 10:27 AM
Motor Tuning PEU Mach Software (ArtSoft software) 3 09-26-2005 11:48 PM
