Results 1 to 7 of 7
Thread: Increment the Z.
    Dec 2006
    Sweden
    Increment the Z.
    Is there an easy way to run a program over and over and just increment the Z cutting at each run?
    Like if I want to cut out a circle in 20mm mdf, and i only can cut 5mm at a time.?
    Mar 2003
    Shelby Twp, MI....USA
    Try the Multi Pass wizard.
    Dec 2006
    Sweden
    Hmm I tried that now, but I cant get it to work correctly
    Att each pass it just cuts at the same level as the first one.
    And if i set the Maximum cut att first pass, to for example 4mm then it started at 4mm when it was supposed to be in the rapid plane.
    If someone could describe the process step by step what has to be done when importing a dxf to get it to work correctly it would be very kind.
    Say if i wanted to cut 4 times and 5mm at each cut.
    Dec 2006
    Try using LazyCAM. You can set the number of passes. Quick and Easy.
    Brian
    Registered holbieone's Avatar
    Feb 2007
    take your original tape open it in a text editor
    copy and paste the number of passes you want
    edit you "Z" move accordingly
    may seam like a long process but most times it's faster then changing your cam program and re posting the tape
    Dec 2006
    Sweden
    Thanx for the answers, i tried lazycam and it works great, for some reason i get a "Error on line 240" msg when i try to use the multipass wizard,
    This line "NewFile = Mid(OldFile, S , L-1)"
    but when i imported the file in lazycam first and then opened it in mach3,
    the wizard worked?
    And the reason it acted a little crazy the first time was that my Z axle was inverted
    Jun 2006
    I've only done this a couple of times, but just changed the Z-DRO value at the end of one pass before running the code subsequent times.
    Mike
    1. Stepper Increment Advantages
      By CNCadmin in forum General Metal Working Machines
      Last Post: 03-09-2004, 09:36 PM
