| Machines running Mach Software Discuss your set-up and experiences running your machine using Mach software here. |
The jerkiness probably is centered on the user, not the control results. I'm using mach3 on a gantry router that travels approx 4x4 feet. I use bobcad v21 to program more complex paths. Anytime the path transitions from one line to the next, for example: g2 then g1, or g1 to g1 transitioning in an angular move, the control comes to a complete stop between each block. Yesterday I had to cut a convex portion of a sphere, and bobcad wrote it as thousands of straight line segments, resulting in a path that starts and stops thousands of times. Not smooth. I scanned through the different settings available, and didn't see anything that pertained to this, but I have to confess I haven't checked the manual yet. I know that with our Heidenhain TNC360's, there is a parameter you can set, which limits the maximum angle you can transition before the control has to stop motion, but I don't know if this is a similar option I am missing with mach3. |
| Change from exact stop mode to constant velocity mode in the configuration screen. Or put a G64 at the start of your code.
| Mach3 0-5V to 12-24V ?? | jimmychand | Mach Software (ArtSoft software) | 2 | 01-11-2007 06:14 AM |
| Mach3 and VFD spindle | Listeroidsusa | Machines running Mach Software | 2 | 01-08-2007 01:24 PM |
| Mach3 and USB | mikep608 | Mach Mill | 3 | 08-09-2006 12:56 AM |
| Can someone help with Mach3 settings? | Revtech | DIY-CNC Router Table Machines | 8 | 07-23-2006 02:40 PM |
| mach3 please help | nymachinist | CNCzone Club House | 1 | 01-31-2006 06:59 AM |
