Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Machines running Mach Software
Machines running Mach Software Discuss your set-up and experiences running your machine using Mach software here.
Old 01-30-2007, 02:54 PM
venomx999's Avatar
venomx999 is on a distinguished road
Setting up threads/inch...
Where do I set this feature ? I'm using Mach2 and couldn't find that option in the Config.
Live life like you never see another day
Old 01-30-2007, 03:32 PM
Konstantin's Avatar
Konstantin is on a distinguished road
In the motor tuning section, the lower leftmost field "Steps per" , meaning steps per unit, a unit being a 1mm or 1inch depending on your preferences.
You have to calculate how many steps your stepper must turn to advance 1 unit. Just run your calculations taking in account if its full/half/micro step and the gear ratio.
And check the documentation since there are an example given.
Konstantin.
P.S.
Additionally go to "Settings Alt6" screen and press the "Steps per unit" button that lies just above the Reset button, then choose the axis you want to test and input 1 inch for example. Use some calipers to measure the advancement of the axis and if it matches then follow the dialogs accordingly, if it does not matches then input the distance the axis moved in the field and Mach3 will compute the "Steps per inch" on its own.
P.P.S
Sorry, but my instructions are for Mach3. I hopefully you can find a way for Mach2.
Old 02-01-2007, 12:54 AM
venomx999's Avatar
Anyone knows why returning to "tool change" on the Z axis is too fast and cause the motor to skip ??
Old 02-01-2007, 01:17 AM
mxtras's Avatar
Silver Member
mxtras is on a distinguished road
Your motors are tuned too hot. Decrease your accel and max speed numbers.
Scott
Consistency is a good thing....unless you're consistently an idiot.
Set-up / Steps per Unit / Threads per Inch adda Mastercam 2 01-15-2007 04:29 PM
I don't know if they got the mm to inch mixed up..... spunky1974 General Metal Working Machines 3 11-23-2006 09:04 AM
DRO - Metric or Inch DJ Morrow General Electronics Discussion 2 11-15-2004 02:06 PM
turns per inch vs threads per inch pminmo DIY-CNC Router Table Machines 12 08-18-2004 09:27 AM
Saving threads or parts of threads??? flybynight Forum Questions or Problems 4 02-22-2004 12:19 AM
