Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Machines running Mach Software
Machines running Mach Software Discuss your set-up and experiences running your machine using Mach software here.
Old 12-13-2006, 08:17 AM
*Registered*
gone4pepsi is on a distinguished road
miniteech help needed
I have a minitech 2 and i do not know the pin configuration. I did have someone send me a file which replaced the file in the mach 3 folder, but still to no avail.
I've downloaded mach3, but it appears my problem is my softare seeing the mill. i know i'm getting power to the motors, becasue when powered up they are held tight in position.
However, the problem i'm having is when i boot up the pc when connected to the mill, it wants to installl new hardware. Alsomst as if it's looking for a driver for the mill.
Also, unpon initiating mach 3 I get two messages plugin defective reload and gall dll defective found ignoring.
Did I possibly install mach3 incorrrectly?
i fi unplug the paralell cable i don't see xp looking for new hardware.
Can amyone help?Thanks
Mark
Old 01-24-2007, 11:21 PM
finance is on a distinguished road
Arrow Try this...
Mark
I can't help you with the pin-outs for your mill, but it sounds like you have your mill powered on when you boot XP. XP 'diddles' with the ports when it fires up to see what is connected - that's why it says it found new hardware.
Power up the PC without the mill powered up (i.e., no power to the drivers/motors), then run Mach3 and then power up the mill. If you do that, and you have followed the Mach3 install instructions correctly then that should fix that part of the problem.
For X axis try entering pin 1 for step and pin 2 for dir with a port of 1. Try all sorts of pin and port combinations - you can't hurt anything but be ready to hit power off on the mill or Esc on the keyboard if the mill runs away (unlikely though).
Download the Mach3 manual for more info on pins and ports and precise instructions for installing Mach3. You also need to know the port address, there are some common ones listed in the manual I think.
If you still get the Mach3 error messages I suggest you rebuild your PC with a clean XP install and re-install Mach3 (without the mill connected), then follow the sequence I mentioned above for powering up.
Hope this helps,
Dave.
