Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Machines running Mach Software
Machines running Mach Software Discuss your set-up and experiences running your machine using Mach software here.
Old 11-17-2006, 04:26 PM
Mike Boarman is on a distinguished road
mach2
I am a new user of mach2 and I accidentally lock my self out of the configuration of the demo version. Does anybody know the password to unlock Mach2 demo version?
Old 11-17-2006, 06:40 PM
ger21's Avatar
Try None or Mach1Pass.
Old 11-17-2006, 08:55 PM
That worked!!! thank you. Now if I can just get it configured so that the motors will run I will be in good shape. Thanks again
Old 11-17-2006, 08:57 PM
ger21's Avatar
Why are you setting up Mach2 and not Mach3?
Old 11-17-2006, 09:03 PM
Is Mach 3 easier to configure? Are you experinced in wiring limit switches? I am sending 5VDC through a 470 ohm resistor through 2 switches and to ground. If ground is broken then to Mach2
Old 11-17-2006, 09:09 PM
ger21's Avatar
You basically configure them both the same, but Mach3 has a lot more options and features. Development on Mach2 stopped about 2 years ago. Sorry, no advice on the limits.
Old 11-17-2006, 09:13 PM
Thanks for your help!!
