Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Machines running Mach Software
Machines running Mach Software Discuss your set-up and experiences running your machine using Mach software here.
Old 11-11-2006, 04:11 PM
bigz1's Avatar
bigz1 is on a distinguished road
steppers stopped working?
I have recently succesfully installed my driver(Hobby CNC 4 axis kit). The motors were jogging but after unistalling the A axis recently(while board was turned off) I cant get the motors to rotate. I haven't turned off the jogging or inhibted any axis. I have since tested limit switches which worked fine.
I suspect during the learning procees I have turned something off in the software but cannot figure out what.
Thanks in advance.
Liam
Old 11-11-2006, 05:55 PM
ger21's Avatar
Triple check all the port and pin settings. Especially make sure the port address is correct, and that each pin is assigned the correct port.
Old 11-11-2006, 07:29 PM
bigz1's Avatar
Thanks for the advice Gerry. Pins are correct to the board. But how do I check the port address is correct?
It currently says 0x378.
Liam
Old 11-11-2006, 07:47 PM
ger21's Avatar
In device manager, check the resources tab for the parallel port.
Old 11-11-2006, 08:12 PM
bigz1's Avatar
Resource reads:-
I/O Range 0378 - 0375
I/O Range 0778 - 077B
DMA 03
Liam
Old 11-11-2006, 08:57 PM
ger21's Avatar
Looks like it's set right, then. Are you sure you didn't change any wires?
Old 11-11-2006, 09:05 PM
bigz1's Avatar
Only disconnected 1 motor and left the others on. Thanks for your patience Gerry.
Checked the E-stop setting in ports and pins and thats ticked but set to 0,0. Motors are hissing but not moving.
Old 11-12-2006, 03:29 PM
bigz1's Avatar
Is their a way of resetting the program to its original settings? I will then re enter the pins/setting and try again. Or will I have to reinstall?
Old 11-12-2006, 04:24 PM
ger21's Avatar
Delete the mach3mill.xml file
Old 11-12-2006, 05:12 PM
bigz1's Avatar
Did that Gerry thanks. Retyped ports and pins and nothing.
Liam
Old 11-12-2006, 05:17 PM
ger21's Avatar
I'd try uninstaling Mach3 completely, and reinstalling it. Make sure you reboot after the uninstall.
Then, set up a single axis and nothing else, until that axis works. Try MDI mode as well as jogging. You probably need to check if your parallel port is outputting the correct voltages to the pins.
You said it was working fine until you removed one motor? Also check the power supply, basicaly go through everything with a fine tooth comb. And try to get ONE axis working before trying anything else.
  #12   Ban this user!
Old 11-14-2006, 05:44 PM
bigz1's Avatar
Followed all the instructions above and still no result. Went through the driver kit with a fine tooth comb nothing obvious wrong. I will borrow a spare printer cable tommorrow to see if that has an effect.
Limits and homing switches work fine.
Liam
