Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Machines running Mach Software
Machines running Mach Software Discuss your set-up and experiences running your machine using Mach software here.
Old 10-15-2006, 02:30 PM
norvil1 is on a distinguished road
blue screen of death
this my first post.i have been reading for last few months.i have recently
purchsaed a shoptask,tripower with cnc set up.i have not recieved it yet,
so i downloaded mach3 to get familar with it.my computer is a lap top
with no 25 pin printer port.when i shut off the computer it locked up,called hp
and they got my computer back running. should i uninstall mach3?? if so how
Old 10-15-2006, 02:56 PM
JRoque is on a distinguished road
Hello and welcome to the forum. The subject of your post referenced a blue screen crash - at what point did that happen? By the way, unless you have a special controller for your motors Mach software must have a real parallel port on the PC. USB to parallel port converters will not work.
JR
Old 10-15-2006, 03:08 PM
the screen locked up when i tried to shut down computer. this has only happened after i downloaded mach3. is it possible to uninstall and reinstall
without the driver and use as a test program.?
Old 10-15-2006, 03:30 PM
Yes, it is possible to install without the driver. See if you can fix the CPU speed by disabling any battery conservation option it might have. Also, be sure to wait a minute or two after quitting Mach before you turn the PC off or put it in any stand-by mode. The engine remains running for a few seconds after Mach unloads.
JR
Old 10-15-2006, 04:24 PM
dertsap's Avatar
Gold Member
dertsap is on a distinguished road
open the mach folder and click on the special driver ,
should fix your problem
