Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Machines running Mach Software
Machines running Mach Software Discuss your set-up and experiences running your machine using Mach software here.
Old 09-19-2006, 08:48 PM
*Registered User*
bo whipkey is on a distinguished road
need mach2 help
[new user...first post
hello everyone
i have new k2 machine and am using the trial version of vcarve pro
i am also using mach2 software
i am having trouble setting them up together...
when i load the g codes theycome out incomplete
and different sizes ...
i have had one of the files cut correctly
it was simply a border from one of the evaluation files
but the fonts inside were screwed up...
i would appreciate any help
thanks
Old 09-19-2006, 08:56 PM
ger21's Avatar
Do you have a license for Mach2? That will cause an incomplete part, as you'll be limited to 1000 lines of g-code.
Does the machine work correctly when not using V-carve? If so, then it's most likely a Vcarve setup problem.
Also, try to ask more specific questions (or give more details), and post pics whenever possible. Makes it easier for people to help you.
Old 09-19-2006, 09:02 PM
*Registered User*
thanks for your fast reply...
i have not cut anything yet and have no pics !
i assumed this might have been a common problem
wi.th a relativley simple fix
thanks again ,i will check the 1000 line angle.
Old 09-19-2006, 09:11 PM
ger21's Avatar
You need to get Mach2 setup and working properly first. Once you know its setup and working correctly, then start working on vcarve.
Old 09-20-2006, 07:17 AM
Tony Mac is on a distinguished road
Hi Bo,
When you open a VCarve Pro toolpath file in Mach2 do you see the lines of GCode in the edit window and a preview of what the file should cut?
Are you running with the Demo or Full version of Mach2?
The 1000 lines of code limit in the Demo version of Mach will allow you to run 2D toolpaths (Profile and Pocket) but almost certainly not any 3D VCarving toolpaths as these typically require more lines of code.
It's also worth checking that the feedrates specified for the toolpath are appropriate and not too fast for the stepper motors.
E-mail any additional information - pictures or files etc. to - support@vectrc.com
Tony
Old 09-20-2006, 01:30 PM
*Registered User*
Smile mach2 trouble
thanks tony,
i do see the code and the preview which is usually incomplete.
the smaller file (rectangle) comes out fine..
i think i need the full version of mach2 and v carve pro 3.1
talk to you soon,
thanks
bo
