Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Machines running Mach Software
Machines running Mach Software Discuss your set-up and experiences running your machine using Mach software here.
Old 06-27-2006, 09:58 AM
TheNigerian is on a distinguished road
Red face Why Do Mach2' Settings Change?
I set the axes limits in mach2's to match the physical dimensions of my machine a while back.
This weekend, after about 40 minutes of machining, I decided the roughing steps were too fine and changed the roughing steps from 25% of cutter diameter to 100% in RhinoCAM, post-processed and tried to machine the the new g-code by starting from the same point. The cutter diameter = 6mm.
What happened was that the previous work was cut away and the more jagged steps I expected to see did not appear.
I gave up 40 minutes later. I checked the motor settings in mach2 and discovered they had changed - radically. They no longer matched the machine's dimensions.
I had not effected any changes in mach2.
Does anyone know what I did wrong and how I can keep from repeating the mistake?
Old 06-27-2006, 10:17 AM
mxtras's Avatar
Silver Member
mxtras is on a distinguished road
I have seen odd things occur with previous versions of MACH as well but I haven't had an issue with the newest version of MACH3.
I would suggest downloading the latest and greatest version now since it appears that you will be setting everything back up - why not set it back up with a better version? MACH 3 runs the motors smoother than MACH2 anyway - you will see a noticable difference in motor control.
Scott
Consistency is a good thing....unless you're consistently an idiot.
Old 06-27-2006, 10:28 AM
Scott, I thank you.
However, do you have a link to such a download?
Old 06-27-2006, 11:42 AM
mxtras's Avatar
Silver Member
Yup - sure do!
http://www.machsupport.com/artsoft/index/index.htm
Go to the downloads page for the files. I have been running Mach3 Dev. Version 1.90.053 without issue.
Scott
Old 06-27-2006, 12:05 PM
Yup. Scott is da Man!
Thanks bud.
