07-14-2006, 11:59 AM
Originally Posted by mikkojay Thanks Gerry-
I was having a heck of a time getting the Mach software to import dxf files exported by Corel without giving a "blank" error message and no results. Corel has a bunch of formats to choose from when saving a dxf file, like versions 11,13,14,2002, etc...
I could not get any of them to import into Mach. I ended up saving the (originally eps files) as *.plt and imported them OK that way. They looked pretty good to me that way, but I sure wish I could figure out what the deal with my dxf format is. The import section in the user manual doesn't go into much detail on this topic.
Thanks, Mike |
I have X3 and I have to save it as plt. If i save as dxf it wont import. One thing that sucks is when you import the plt into lazy cam it wont allow you to set depth, only when a dxf is imported can you set depth least thats my experiance.
__________________ Theres a good side to every bad side, you just have to look around the corner. |
