| Machines running Mach Software Discuss your set-up and experiences running your machine using Mach software here. |
#13
Thanks.. But I need a solution to the problem rather than a work around. There are too many tabs etc to even consider changing code.. it would be easier just to do Normal tabs instead of Ramp/3d tabs.... As I said above.. they work fine on straight sections, curves are the problem for the tabs. [ |
#15
| Moondog, I understand what your saying, you think you have a problem with the way Mach is interpolating those curves, I was thinking that maybe your just at your max speed, and Mach or your hardware wont crunch any faster. Thats basically why I do what I do, because if I run at an acceptable speed for all conditions I'm limited to less than 50ipm, whereas is I use diferent feed rates I can get much faster overall program runtimes. I HATE listening to that router screaming away for hours on end.
__________________ Halfnutz (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
#16
| Moondog, Maybe you can try adjusting the "Look Ahead xx Lines" value to something greater? I don't remember where the setting is in Mach 2. It's under Config -> State..... on the Mach 3 toolbar. The default for Mach 3 appears to be 25 lines. Have you tried Mach 3? It amazes me how many Mach users are still using version 2. I know it takes some time to reconfigure Mach 3 and the screens are a little different, but, the latest Mach3 Dev. Version 1.90.051 (Click Here) just SCREAMS! Mach 3 runs much smoother than the previous version that I was using and I was able to adjust my feed rate from 33 ipm to ~60 ipm. I had to run the previous version of Mach 3 at 33 ipm due to lost steps during multi-axis moves. Simultaneous X-Y-Z axis moves, 45 degree X-Y axis moves, and 90 degree radius curves went all haywire at any higher cutting speed. Sound familiar? Just curious, what is your "displayed feed rate" versus your "programmed feed rate" when cutting the 3D bridges? I noticed that when I had a programmed F40 that the displayed feed rate was between 60 and 80 ipm on the cuts approaching 45 degrees, simultaneous 3-axis moves and 90 degree radius curves. This was well above the 50 ipm velocity setting I set up in the Motor Tuning screens, also. BTW, before anyone asks, the 50 ipm was ~80% of the velocity where my motors stalled or visibly lost steps. The displayed feed rate in Mach 3 is also higher than the programmed feed rate for the types of cuts noted above but so far I haven't noticed any issues except for circles. I've got to slow down a bit to say 40 ipm on circular cuts but it is still faster than the original 33 ipm. Why does/can the displayed feed rate be considerably higher than the programmed feed rate and/or the velocity setting in the motor tuning setup? Art? Someone? Anyone? Curiosity killed the cat! Good thing I'm not a cat!!, HayTay
__________________ HayTay Don't be the one that stands in the way of your success! |
#17
| Hello Hay Tay... sorry for the delay in responding... seems like the problem is that Mach cannot handle the amount of moves required. too many small moves.. I am cutting at 7000mm/min (around 300in/min). Also I am doing my NC code in Artcam and it looks loke Artcam creates too much code for these moves... Will look at doing the code in alphacam instead. I also have noticed that the DRO's on Mach show much higher than the speed settings... for example... I have my machine set at 7200mm/min maximum. Sometimes during the rapids the DRO's show around the 10,000....???? strange..... Mach does have its problems... Also mach errors if you try and increase the feed rate over 100%... something that needs to be fixed ASAP... Apart from Mach.. what are our other options?... Moondog |
#18
When you say Mach errors at over 100%, what do you mean?
#20
| Hi Moondog I believe the reason Mach shows a rapid greater than your maximum setting is when you are running two or more axis at once. For example in your case if your maximum single axis velocity is 7200mm/min on both axis then you could achieve a maximum rapid of 1.414 * 7200mm/min if you were running x and y ie 45 degree movement. The value shown for the feed/rapid rate on the DRO is the value of the velocity vector created between two points, not the maximum for one axis. When you rapid (G0) all axis involved are running at their maximum velocity set by you in Mach. When you feed (G1) each axis velocity is controlled to achieve the desired feed rate set in the program. In your example the maximum velocity you could achieve with a 7200mm/min setting per axis (x and y only) is 1.414 * 7200 = 10180mm/min. If you were to add in a Z move at the same time the DRO rapid value would increase again. Cheers
__________________ <insert witty comment here> derekj308 |
#21
| Program to the fastest speed you'll want to go, and use FRO to slow down only. That's how our commercial router works. Just start with the FRO at 50%, or whatever you want. If you program at F100 and want to go up to 200, program at F200 and start with the FRO at 50%. Exactly the same, but you won't have any problems going faster.
