Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Machines running Mach Software
Machines running Mach Software Discuss your set-up and experiences running your machine using Mach software here.
Old 05-22-2006, 04:33 AM
TheNigerian is on a distinguished road
On the Z-axis, All Movement Above Zero Are Positive - Right?
I own a K2-2514 cnc routing machine.
Wherever I set the z=0 point along the z-axis, all movement above 0 are indicated as negative in mach2. And - of course - all movement below 0 are indicated as positive.
This is not correct.
The result has been that for all profiling jobs I have attempted, I am a newbie, the machine has attempted to start cutting from the deepest point in the stock.
Is there a way I can adjust this?
If I have to live with this, would reversing the polarity of all z values in my g-codes solve the problem?
Old 05-22-2006, 07:19 AM
per.e is on a distinguished road
Hi there.
In Mach3 go in to "config" and then "homing/limits".
In there change the settings for the Z axis.
Best regards:
Per
Old 05-22-2006, 08:06 AM
joecnc2006's Avatar
www.joescnc.com
joecnc2006 is on a distinguished road
Originally Posted by per.e
Hi there.
Best regards:
Per
Meaning reverse it in the software, this is normal on many machines, like on the gantry it depends on which side the motor is installed as to which way is positive and negative moves are done. and also depends on if you have left hand or righ hand lead screws.
Old 05-22-2006, 09:46 AM
I use mach2.
Taking your advise, I visited config/homing. The advise is:"Homing direction : ... Homes towards minus when checked". Not quite what I had in mind.
Then I noticed Config/Motor Reversals: "Check box to reverse an axis"! I have checked the Z-Axis and will get back to you with the result.
Thanks for the steer.
