Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Machines running Mach Software
Machines running Mach Software Discuss your set-up and experiences running your machine using Mach software here.
Old 01-08-2006, 10:17 PM
kn6398 is on a distinguished road
Mach3 motor tuning question
OK, I just finish building my CNC router base off of Joe2000che's and JGRO's plans.
I have the hobbycnc driver with 3 200oz 1.8 degree stepper motors and 5/16 18 tpi lead screw. I'm trying to configure the motor tuning page in Mach3. I been searching and reading in the forum on how to tune the motor but could not find out how to calculate the step per. I understand for the Accel and Velocity you just try error until you get the motor to stall and decrease it by 20% but for the "steps per" not sure how to obtain or calculate it. I'm pretty sure there is a thread on this already but I can't seem to find it.
Any help will be great. By the way did I mention I was a newbie.
Old 01-08-2006, 11:02 PM
joecnc2006's Avatar
www.joescnc.com
joecnc2006 is on a distinguished road
200 steps per revolution x 18 turns per inch (5/16"-18 rods) = 3,600 full step or 7,200 1/2 step and so on depending on the step jumpers you set on your board.
Any pictures of your machine? like to see a post on it.
Joe
Old 01-09-2006, 05:10 PM
Joe
I guess my value will be 3600/.25=14,400 for 1/4 setting on my board.
My first test cut "the famous road runner". I haven't fine tune it I was to excited and couldn't wait.
Name:	whole table.JPG‎
ID:	13696   Click image for larger version
Name:	z axis.JPG‎
ID:	13697   Click image for larger version
Old 01-09-2006, 05:15 PM
joecnc2006's Avatar
www.joescnc.com
yes that is correct 14,400 is what i had mine at 1/4 step. That is a nice looking machine. When i finish my new machine remind me to send you the files and g-codes so you can make it yourself.
Old 01-09-2006, 05:28 PM
I wouldn't had done it if you hadn't cut most of the small part for me.
The parts you cut came out looking real good.
You will reget saying that I will be bugging you for the new maching file you're working on.
Old 01-09-2006, 06:13 PM
joecnc2006's Avatar
www.joescnc.com
The parts i sent you came from my second machine just like the one you just built and also it cut the parts for my new CNC Model 2006 Machine.
so i know it works well... lol
Old 04-04-2006, 01:14 PM
GaryM is on a distinguished road
Help,
I have a 3 axis xylotex kit and I am running it with Mach 3. I have the motor tunning steps per set at 14,400. When the dro say's it has moved an inch it really has only moved a half an inch. My lead screw is a 5\16-18. So do I need to increase the steps per value in the motor tunning?
Gary
Old 04-04-2006, 01:29 PM
joecnc2006's Avatar
www.joescnc.com
Originally Posted by GaryM
Help,
Gary
check your microstepping on your controllor board, try setting steps to 28800 to match the board. Looks like you have it set to 1/8 step.
Old 04-04-2006, 01:30 PM
ger21's Avatar
Help,
Gary
Yes, double it.
Old 04-04-2006, 11:07 PM
Thanks alot guy's, that was it. I set it to 28800 and know it's dead on. Once I get the Z axis done I'll be makin chips.
Gary
