Did you check Auto Screen Enlarge in General Config, and then restart mach3?
If that doesn't work, the only other option is to create a new screen, or find one that someone else has done.
Does anyone know how to (re)-configure Mach screens for use on 10" LCD Panel-PC?
The screens do not conform to the display height and width with the required 800x600 res.?
Thanks gerry that did it, it was just when Mach loader was used, but the likes of the Config screen are still way too large as it does not have the top right sizing boxes?
Your stuck on that one, as everything was designed with 1024x768 in mind.
