Results 1 to 3 of 3
Thread: mach3 motor spins one way
    Oct 2011
    Hello I have an issue with a computer that is setup with smooth stepper and has three ports 1,2,3. there are x,y,z,a axis enabled in mach and x,y,z all turn properly but "A" doesnt. I have checked for continuity on all 4 of the wires from db25 board to stepper drive for "A" and motor will run in 1 direction but not both, if I switch step and direction pins motor will spin in other direction? swithing high or low doesnt do a thing and Ive tryed or made sure that polarity is not an issue as well with step-+ direction-+ etc... used different port as well. Im at a lose? I think ill try a new drive, but not sure. Any idea will be thanked"!
    Oct 2011
    I seem to be able to change direction just by changing step and direction pins on ports and pins for motor output but yet when I jog it will only go 1 direction or the other with the change but not both. This is a stepper driven axis and the others are servo, they are all hooked up the same and I've tried a new drive for stepper. The motor has the same resistance as a new motor, and I'm using cw250 drive with cp+- and cw+- the only thing I have not tried is changing the windings configurations etc... Beginning to p me off.
    Oct 2011
    Solved problem
    Seems as thought a dip switch was wrong on the drive works good now, thanks for any views.
  1. Mach3 motor set up, please help
    By ICSLLC in forum Mach Plasma / Laser
    Last Post: 08-10-2010, 01:53 PM
  2. Open Collet While Main Spindle Spins
    By danrudolph in forum CNC Swiss Screw Machines
    Last Post: 12-24-2009, 10:44 AM
  3. Need Help!- Motor just spins continously. G320X
    By Pairair in forum Gecko Drives
    Last Post: 12-15-2009, 10:05 PM
  4. New Machine Build- Mach3 , Config, Motor Tuning problem ( FILM OF MOTOR)
    By MDF_Markazi in forum Mach Software (ArtSoft software)
    Last Post: 04-30-2009, 03:15 AM
  5. Replies: 33
    Last Post: 12-09-2006, 11:30 PM
