Results 1 to 4 of 4
Thread: 5 axis probing. Can Mach3 do it?
    Registered neilw20's Avatar
    Jun 2007
    Can Mach3 handle automatic probing of shapes on a 5 AXIS machine.
    Super X3. 3600rpm. Sheridan 6"x24" Lathe + more. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
    Mar 2003
    Shelby Twp, MI....USA
    Not positive, but I think only XYZA.
    Jun 2007
    Thanks Gerry.
    Is it possible to write some macros to handle multiple probing.
    Somehow I need to make a heap of coordinates get stored somewhere.
    Not just a single point. Needs to be automated. Process them later.
    Pre CNC era parts need to be duplicated for repair work.
    Hit a spot. Log location. Move to next scan location.
    How is it done, or is probing just only for toolsetting oneshot type hit.
    I've manually logged a heap of spots before with one of the wizards.
    This needs to be automated.
    Mar 2003
    I believe you use the G31 probe command. But I think it will only write XYZA data to the point cloud file.
  1. Z-Axis Move During Comp X/Y Probing
    By jduckjr in forum Tormach Personal CNC Mill
    Last Post: 05-07-2011, 11:29 AM
  2. Need Help!- How to assign 5th & 6th Axis to Slave when Pin 2-9 already used in 4 Axis for Mach3
    By guy2b1 in forum General Electronics Discussion
    Last Post: 10-29-2009, 09:09 AM
  3. 5 Axis probing on 88hs -4 system
    By carbidecraters in forum Fadal
    Last Post: 04-02-2009, 12:20 PM
  4. setting up 4th axis for DIY probing in Mach?
    By Rich05 in forum Digitizing and Laser Digitizing
    Last Post: 01-16-2009, 09:43 AM
  5. probing software for Mach3
    By stirling in forum Digitizing and Laser Digitizing
    Last Post: 11-23-2007, 12:19 PM
