I am trying to mill a circle in a piece of MDF for a project I'm working on. If I use a compass and draw a circle on the MDF then using a 1/8" 4 flute flat bottom bit and do and Outside cut using Cut2D, the bit doesn't follow the line I drew with the compass. It will start out in the correct place but as it moves around the outside of the circle the bit will move away from the line by 1/16" and then move back to the line, cross the line on the inside of the circle by 1/6" and back to the beginning. I am using Mach 3 Version R3.043.022
I went back and double checked my X, Y movement and both axis's move the distance I tell them.
So I started from the corner of the MDF and made a mark in the X at 4.5" and from there made 2 marks in the Y direction. One at 2.5" and the other at 4". I drew a line from the corner to each mark so I could see if the bit followed it when moving from 0,0 to 4.5,2.5 and 0,0 to 4.5,4
With the 1/8" bit setting at 0,0 centered on the corner I used the MDI to move to the 4.5,2.5 location and the center of the bit followed the line . When I went from 0,0 to the 4.5,4 the center of the bit was off by about the thickness of the bit.
Is there a setting in Mach 3 that I may have missed that will correct this?
Thanks for any help you can provide
John Frankforther
LinkBack URL
About LinkBacks
