| Machines running Mach Software Discuss your set-up and experiences running your machine using Mach software here. |
hi folks just finished putting everything together couple days ago. got a pmdx 132, 3 G203V, mach3 demo. basicly, everything seems to be fine but nothing works. motors are not turning at all on all 3 axis. i have green lights on the gecko drivers e-stop is ok(i can actually reset it in mach3 and nothing is acting funny there) i doublechecked and yes i did enabled the parallel, its the good port and it works(i have a little software who tells me whenever theres a pin that is recieving either high or low) i just took out the centronic to db25 cable and checked every pin to make sure theres continuity with comething at the other end. didnt found anything wrong there axcept pin1 on db25 who dont seems to be used anyway dc power is ok green lights on the gecko drivers; means everything is ok triple checked all conexions from stepper to stepper controlers its hard to mess up with the pmdx, its plug and play. nothing can go wrong there. my little software do tell me that: mach3 setup is: step: 3 5 7 dir: 2 4 6 my software do tells me that theres a high on 2,4,6,. 3 5 and 7 stay low i just dont get it. any ideas |
| Do the DRO's change when trying to jog? If so, jog back and forth and measure the voltage on the direction pin. It should be 0V in one direction, and 5V in the other direction.
| Can you use a multimeter to measure the direction pin output voltage for each axis between the pmdx 132 and the geckos, and see whether it changes when you jog each axis in different directions (edit: I wrote this before I saw the response from ger21, n/m)... |
| yes the dro move. I will check voltage at the steppers tomorrow. I can confirm that on the parallel port they do change, I have a software that tells me the state of every pin. 2, 4 and 6 do turn high in one direction only. I will chek that voltage on the gecko. more to follow. thanks a+ ben Last edited by cowboy; 02-05-2012 at 11:31 AM. Reason: corected some mistakes |
| I just finished wiring my 203V and the problem I had was with Terminal 7 (Disable) when wired to the Bob (C11G) +5 volts it did not work. I removed that wire and now everything seems to work. Also regarding the green lights, one the power LED was green, but the Error LED was red in my case. |
| hi everyone i did a little bit of testing. i have 4 optoisolated terminals on the gecko. disable step direction and comm if i dont touch anything, axis are not suposed to mode, dro dont more as well disable is low step is high direction is high comm is high (i tough it was a ground. . . . .) both direction: disable is low step is high direction is high comm is high (i keep thinking its a grnd. . . .) i tested on two axis, just to be sure. what i dont get here is: they are all suposed to be low, and then i am suposed to have the pins 2, 4 and 6 wich are direction, at high. parmon, that software i am using, switch pins 2, 4 and 6 to high in one direction only. . . . its on those pins that mach3 is configures. on the geckos, i dont see it. next step there, i will locate all the pins that are interesting for me on the parallel port, and test them on the centronic. |
| I don't follow what you're doing, as it's apparently over my head. ![]() Just jog back and forth, and measure the voltage on the direction pins for each direction.
#10
| The G203V doc says that the optoisolator common is ground ("The COMMON return for the signals is controller ground referenced instead of +5VDC."). So you may want to switch those jumpers to their alternate positions and retry your tests. |
#11
| its wayyyyy over my head too ![]() ![]() i did jog back and forth. nothing changes on the direction pin. while i was there, i checked all 4 pins, and thats what i got. sorry, i wrote high and low, read almost 5 volt and almost 0 volt. i am far to be good at that stuff ! doorknob: i did checked those jumpers, and they are at coom: grnd. thats why i tough they would be ground G203V is suposed to be grnd on the common. i will take a look at that. just tested the jumper at +5v: nothing changes. . . . . . what could cause the pmdx to make all that stuff not working. . . . . . i putted a jumper on the e-stop instead of a switch to be sure, as far as i know, its the only stop that i have. Last edited by cowboy; 02-05-2012 at 11:54 AM. Reason: tested the jumper at comm +5v |
#12
| Need Help!- Only Y works correct X don't work Z works one direction only | jdgbadenhorst | Hobbycnc (Products) | 1 | 05-20-2012 06:26 PM |
| Mach3 fail, forward works, backward failed | kievari | Mach Software (ArtSoft software) | 0 | 02-21-2011 03:21 PM |
| Mach3 works at seller's shop, but not at home.. | Catharsis | Mach Software (ArtSoft software) | 3 | 01-25-2011 12:51 PM |
| Need Help!- Controller works with Mach3 but on EMC2 it wont work but other mill does so ? | Tkamsker | LinuxCNC (formerly EMC2) | 14 | 10-26-2010 11:00 AM |
| Works in KCam, Not working in Mach3 | Cooper | Mach Software (ArtSoft software) | 2 | 03-11-2007 11:41 AM |
