Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Machines running Mach Software
Machines running Mach Software Discuss your set-up and experiences running your machine using Mach software here.
Old 01-25-2012, 01:32 PM
ros2468 is on a distinguished road
Mach3 and parallel breakoutboard PINS
Hello,
Im trying to setup a breakout board with mach3.
I have a breakout board and a stepper driver for higher voltages.
The driver is an l298 and has input ENA IN1 IN2 IN3 IN4 ENB,
output motor A(1,2) and motor B(1,2).
When ENA and IN1 or IN2 is high the output A is VMS, same with ENB.
I have setup a dir and step in mach and tried to wire them to driver inputs but motor only locks up or buzzes.
This is my first breakout wiring, the motor is a 4 wire.
Old 01-25-2012, 10:01 PM
springlakecnc is on a distinguished road
Hi, pin setup can be a pain. Take a minuet and check your ramping time and rapid traverse. Outside chance you have it wired correctly, but maybe set up parameters are asking it to hit more than top RPM, in no seconds! Good luck
Old 01-26-2012, 06:16 AM
Yes, ive come to think of if i where to connect the stepper straight to the lpt, does mach3 support that?
Old 01-26-2012, 06:56 AM
neilw20's Avatar
neilw20 is on a distinguished road
L298 is just a driver chip for the stepper, or linear brush motor.
You need dirive circuitry to sequence the 4 inputs.
This chip is normally driven from some sort of CPU, or another pre-driver chip.
To drive it from Mach3 you need a L297 chip driving the L298
Download application notes/data and study them. See page 8...
http://www.learn-c.com/l298.pdf
Super X3. 3600rpm. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
john_100's Avatar
john_100 is on a distinguished road
Hi ros2468 ,
are you using a L297 IC to convert the Mach 3 step and direction signals
to the 2 enable and 4 inputs for the L298 ???
the circuit diagram for the board you have built will make it easier to help
this step and direction tester circuit from Gecko drive com
could help you to test your driver board :--
John
Old 01-26-2012, 06:58 AM
neilw20's Avatar
We both hit the same nail on the head at the same minute, half a world away!
Old 01-26-2012, 07:20 AM
john_100's Avatar
we did
I wonder how many times that happens ??
John
Old 01-27-2012, 07:45 AM
Hello again. Ive searched the google for a solution and come up with this schematic for a l298 & l297,
If this works with mach3 ive have 2x l298 per l297,
Here is a picture.
Old 01-27-2012, 08:00 AM
neilw20's Avatar
This is easier than L6203, but dissipates more heat, but is easy to add heatsink.
Either will work with Mach3.
Old 01-29-2012, 06:08 PM
Thanks that is what i have looked for. would i be able to wire the l297 to a 4 wire outputs for a mach3?
  #11   Ban this user!
Old 01-29-2012, 06:45 PM
neilw20's Avatar
Mach3 direction pin goes to CW/CCW (17 on L297)
Mach3 step pin goes to CLOCK (18 on L297)
You allocate the Mach3 pins in Mach3 ports and pins, etc.
You need to terminate the other pins on L297 according to the L297 app notes.
The circuit layout details are important as far as correct connection of the 0v and sense pins, for the circuit to function as designed.
see page 16 for what needs to connected to each pin, and it's function.
http://www.technologicalarts.com/myfiles/data/AN470.pdf
Lots of more information, good, bad and suspect
Do a google search for L297 and click on images.
This is close to what you need. Only use as a guide.
L297/298 Stepper Driver
  #12   Ban this user!
Old 01-30-2012, 04:15 AM
cnctga is on a distinguished road
Mach 3
Hi Niel see you are in the same region as me ( New Zealand )
Im looking for someone that has more experience with Mach 3 than me
My Background is Mechanical and i undertook to build a large Router
Wanting to chat to someone and help me iron out the last of the Issues
Jerky movements
Backlash compensation
Homing limits
Tim
Need Help!- G201/Mach3, ports and pins setup xander18 Benchtop Machines 5 05-15-2011 01:41 PM
Problem- Relay control with BOB - parallel port pins are always +5V until CNC software startup FXC General Electronics Discussion 13 02-14-2010 05:50 AM
Parallel port+ input pins for use with EMC visky General Electronics Discussion 0 10-26-2008 04:18 PM
parallel cable pins nicanor76 DIY-CNC Router Table Machines 8 05-14-2008 06:01 PM
Configuration Of Output Pins In Parallel Port FOR 4 AXIS Khalid Open Source Controller Boards 2 05-20-2007 01:55 AM
