Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Machines running Mach Software
Machines running Mach Software Discuss your set-up and experiences running your machine using Mach software here.
Old 12-23-2011, 09:37 AM
precisionhone is on a distinguished road
Help with motor tuning
Hi everybody. I am new to the CNC. I have purchased a sherline CNC mill. I have download mach3 but it will not reset so I can use the prograam. So I downloaded mach2. It works fine. But tuning the motors seems good. I move it .100 and it moves .100 with the indicator. But when I go and run the program. It doesn't move the same eveytime. I have the X moving 2.5" after it drills the first hole and moves to the net locaation. Some times it is short about .100- .150 and times it is long +.100 to +.150 and sometimes it hits right on. Also the Z seems to get shorter with each hole it drills. I am not sure it is missing a step or I don't have the motors tuned right. Please help. I would appreciate it.
Old 12-23-2011, 10:43 AM
ger21's Avatar
Most likely missing steps. Lower the accel and velocities by half.
To get Mach3 working, try toggling the active low setting on the estop pin in ports and pins, input pins.
Old 12-23-2011, 11:04 AM
CurtisBarclay's Avatar
CurtisBarclay is on a distinguished road
I have a similar problem, I set up Mach 3 in Windows 7 and I can't tune the motors using the Motor Tuning and Setup dialog, The motors do nothing when I move the Velocity slider as described in the Video tutorial.
The motors won't turn until I manually input the Velocity and Acceleration.
How can I fix this problem.
Old 12-23-2011, 11:36 AM
ger21's Avatar
You use the up and down arrow keys to run the motors while in the motor tuning screen.
Old 12-23-2011, 12:24 PM
The simplest answers can make you look foolish!!
It works!
Thank you
I'm always having a PICNIC....Problem In Chair Not In Computer!
Motor Tuning john1285 Mach Mill 6 06-24-2010 08:33 PM
New Machine Build- Mach3 , Config, Motor Tuning problem ( FILM OF MOTOR) MDF_Markazi Mach Software (ArtSoft software) 7 04-30-2009 02:15 AM
Motor tuning br1 Mach Mill 1 02-28-2009 07:38 PM
Motor Tuning Smitty911 Gecko Drives 6 10-16-2007 04:40 PM
Motor Tuning dwacker DIY-CNC Router Table Machines 8 04-30-2007 09:50 PM
