Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Machines running Mach Software
Machines running Mach Software Discuss your set-up and experiences running your machine using Mach software here.
Old 09-05-2011, 09:51 PM
kauaicuda is on a distinguished road
Something HAS to be wrong with my steps per inch....
Hi folks.
Im a total newbie, I'll admit.
Im running a cncrouterparts.com design 80/20 build.
I'm using a Gecko G540, Nema 23 steppers, 5 start 10 tpi leadscews, and of course mach3.
I have seen others using steps per inch at "4000"
200 step motors x 10 microstep drives, x 2 turns per inch on the screws.
But, my steps per is only accurate around "160". Thats right, one-hundred-sixty.
I cant figure out what I'm doing wrong. Any ideas?
Old 09-05-2011, 10:12 PM
ger21's Avatar
You probably have your default units set to mm's. Change to inches and retune the motors.
Old 09-05-2011, 10:42 PM
I did check that, I thought it was correct, but now I'm guessing not.
160 x 25.4 (mm in an inch) = 4064
Will recheck and report back.
Old 09-06-2011, 06:44 PM
Yep. Sure was in "mm"
Here's where it gets really interesting.
I reset my steps per inch with mach loaded up with no G code.
I had to set it to about 100,000 steps per inch to be in the ballpark of 1 inch. I knew this wasnt right, but it worked....sort of....The DRO on mach read 1 inch of movement for 1 inch of travel.
Then I loaded my G code, and the steps per inch was no longer accurate. It changed, with my G code loaded, to where I wanted to be, 4000 steps per inch.
Great, I suppose, but why did my "steps per" change when the G code loaded?
Old 09-06-2011, 07:01 PM
ger21's Avatar
You have a G20 or G21 in your g-code, which is changing the units.
You're steps per unit isn't changing.
Set the default units to inches, set the proper steps per inch, and make sure youre g-code doesn't have a G21 in it, and it should work fine.
Calculating steps per inch! Pplug DIY-CNC Router Table Machines 9 12-09-2010 05:03 PM
Steps per Inch Question jtluttrell Linear and Rotary Motion 7 01-12-2010 07:07 PM
Steps per Inch / mm themonster Linear and Rotary Motion 1 08-25-2008 08:08 AM
steps per inch Chris Tucker Linear and Rotary Motion 12 08-14-2008 07:50 AM
Steps per inch formula, What I am doing wrong? Noah Gecko Drives 13 05-27-2004 06:56 PM
