Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Machines running Mach Software
Machines running Mach Software Discuss your set-up and experiences running your machine using Mach software here.
Old 08-24-2011, 12:50 AM
Hauntfreaks is on a distinguished road
Mach3 cutting undersize
Hi... Ive had my cnc router running fine for about a month... I notice the other day a part I cut a few .125 holes for 4-40 screws to go threw... when they were done... the holes were to small.... then today i needed to put a slot in a part... and again it was undersized... I checked my stepper calibration and its dead on.... so I did a test cut... .1x.1 inside dia. square hole, once again undersized came out .085 x .085..... I'm lost .... any help would be great.... heres the G-Code
( test )
( File created: Wednesday, August 24, 2011 - 01:03 AM)
( for Mach2/3 )
( Material Size)
( X= 0.500, Y= 0.500, Z= 0.063)
(Toolpaths used in this file
(Profile 5)
(Tools used in this file: )
(1 = End Mill 3/64)
N100G00G20G17G90G40G49G80
N110G70G91.1
N120T1M06
N130 (End Mill 3/64)
N140G00G43Z0.8000H1
N150S25000M03
N160(Toolpath:- Profile 5)
N170()
N180G94
N190X0.0000Y0.0000F30.0
N200G00X-0.0266Y-0.0266Z0.2000
N210G00Z0.1000
N220G1Z-0.0720F20.0
N230G1X0.0266F30.0
N240G1Y0.0266
N250G1X-0.0266
N260G1Y-0.0266
N270G00Z0.2000
N280G00Z0.8000
N290G00X0.0000Y0.0000
N300M09
N310M30
Old 08-24-2011, 07:19 AM
ger21's Avatar
Probably bit deflection or machine flex.
Try cutting the same size cutout in the opposite direction, and see what size it is?
Old 08-24-2011, 03:44 PM
Gerry.... I think your right... I grabbed a hold of the Z axis stepper rocked it back and forth.... you can see in the video below the result .... I dont understand why only a few weeks ago it was cutting fine.... now to figure out how to fix the problem....
Old 08-25-2011, 06:40 PM
looked deeper into this .... looks like i might have a bad linear bearing on the Y axis.... how would that happen??
Need Help!- .0014 UNDERSIZE dodgetruck23 General Metalwork Discussion 5 03-17-2010 08:08 AM
Problem- Undersize cutting David Ferguson Fadal 3 10-21-2009 03:40 PM
Help! Plasma cutting undersize on X axis Normsthename CNC Plasma and Waterjet Machines 9 10-15-2009 04:51 PM
Undersize Parts 44-henry Tormach PCNC 5 05-20-2009 09:03 PM
Tornado 80 alarms out undersize bar michael88 Colchester Tornado lathes 2 08-23-2008 02:33 PM
