Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Machines running Mach Software
Machines running Mach Software Discuss your set-up and experiences running your machine using Mach software here.
Old 07-24-2011, 03:31 PM
Træstøv is on a distinguished road
Slave not synchronized
Hello everyone
I have build a gantry style router, and i'm using the X- and A-stepper to drive the gantry. The X-stepper is master and the A is slave. Some of the time the steppers move perfectly in sync, but then suddenly one of the steppers loses steps, and drives the gantry out of square. I'm using shielded cabels, and have connected the sheild-wire to the stepper housing at one end, and to the controlbox at the other end.
In "motor tuning" i have tried to set the "step pulse" to 4, which seems to help a little, but it is not good. I will be very greatful to anyone with some advice, on how i get the master and slave to drive in sync.
Regards
Jens from Denmark
Old 08-03-2011, 09:17 PM
Master of nun is on a distinguished road
Hi Jens
I had similar results at one time, I think you may need to drop the velosity down a bit in the motor tuning.
Start off low and increase until it starts occur, then back it off a little bit. If it is still happening no matter how low you set the velosity and accel then we need to look at something else.
You must restart mach3 when setting slave axis, but you are probably aware of this!
also I've found that if I power up motor drives before the PC, I have had slave driving oposite to what it is supposed to.
Regards
Liam
Old 08-09-2011, 03:08 AM
Hi Liam
Thanks for your reply! I still loose steps if I put the velosity and accel way down.
I discovered a few things that hopefully can help solve the problem. Until now I haven't hat a grounded cabel for my computers power supply. Yesterday I changed it to a grounded one, and I found, that if I put it into the same power outlet as the controller, the steppers gets a lot more noisy.
If I use different power outlets for the controller and the computer, the steppers noise level stays normal. -by the way, is it normal that the steppers makes at buzzing sound, when they are not moving?
Another thing I found was, that if i use the Mach3 auto axis calibration function "set steps per unit", the stepper will only move, if I've just moved it in the same direction, as the calibration function is going to move the stepper. If I just moved the stepper in the opposite direction, the callibration function will not move the stepper. Instead the stepper stalls, like when you set the velosity way to high.
Has anyone got an idea what could be the problem?
Thanks in forhand
Jens
Old 08-09-2011, 08:01 AM
Jens
I'm a little out of my depth here, but I will try to help as much as I can. Please anyone out there with some advice?
I think you need to start over and test your output pins with a multimeter to make sure you are getting the voltages you are supposed to.
also check any settings on your motor drives are correct for your setup.
Perhaps you can post some more details of the BOB, drivers etc. you are using.
I don't know if it will help, but try copying and pasting the velosity and accel numbers from the master to slave axis so they are the same.
When you say it will go a little way before loosing steps...how far and how much time roughly?
are the other axis working ok?
Liam
Old 08-10-2011, 06:36 PM
Any progress Jens?
Old 08-12-2011, 12:08 PM
Hi Liam
Sorry it took some time for me to reply! I have working a lot lately...
Someone from the Mach3 forum suggested that I should try turning on the "Shirline mode", because it helped to set a wider pulse. Shirline mode apperently makes the pulses even wider.
A lot of thanks to you Liam, -it really means a lot to get help!!
Jens
Old 08-12-2011, 04:50 PM
Post your results with the sherline mode, it may help someone else later.
Liam
http://www.cnczone.com/forums/cnc_wood_router_project_log/101936-5_axis_build_full_steam.html
Old 08-13-2011, 01:12 AM
I'm not sure that I know what you mean, -should I make a new thred and post it in that one as well?
Old 08-14-2011, 07:12 AM
Frederic Gagnon is on a distinguished road
Hello Jens,
What stepper driver board are you using ? I have a similar problem and am using a TB6560 all-in-one driver/breakout board bought from ebay.
Old 08-15-2011, 12:07 AM
Hi Frederic
I use the 4 axis kit from HobbyCNC:
HobbyCNC PRO Driver Board Packages | HobbyCNC
Jens
to slave or not to slave stef_d DIY-CNC Router Table Machines 4 11-27-2009 11:52 AM
Synchronized PWM moonrock Stepper Motors and Drives 2 08-11-2008 05:22 PM
Lathe: Synchronized C/X axis programming toastydeath General CNC (Mill and Lathe) Control Software (NC) 4 01-17-2008 08:58 AM
Does anyone know of a controller board for synchronized stepper motors Yellowbeard Stepper Motors and Drives 2 04-03-2005 11:06 PM
Looking for controller board for synchronized stepper motors Yellowbeard General Electronics Discussion 0 04-02-2005 08:50 AM
