| Machines running Mach Software Discuss your set-up and experiences running your machine using Mach software here. |
I just got Trend's 6.3mm x 20mm spiral upcut acrylic cutters and need to know what feed rates to set for them to cut acrylic. I use the DeWalt laminate trimmer with a fixed speed of about 24000 rpm. Help needed. |
When your chip load is correct, the heat generated by cutting is removed with the chip. If your chip load is too low (and/or RPM too high), the cutter will tend to "melt" materials like acrylic rather than "cutting" them. However, at 24000 RPM, you would need a feed rate of 96 IPM to get a .002" chip load on a 2-flute cutter. You may want to look at a router speed control to reduce the RPM and allow you to program a "realistic" feed rate with a .001-.002" chip load.
__________________ Bill (the Cat) Shubert |
| Thanks bud. I will enter that feedrate into my code to see what happens. I do own a variable speed Porter Cable 892 - which the manufacturer assures me will fit on my KT-2514. I'll fabricate a toolholder and use that router instead - if I find that I have to. |
| Newbie- Feed rate | csmoak25 | BobCad-Cam | 0 | 03-31-2010 09:51 AM |
| Okuma mill feed rate jumps to rapid feed | easyguy97 | Okuma | 6 | 12-20-2009 04:14 AM |
| Need Help!- Feed rate Ovverride also Increases rapid rate. | Korellibopper | Machines running Mach Software | 1 | 01-30-2008 05:37 PM |
| Feed Rate and Spindle Rate for this cut? | DroopyPawn | General Metalwork Discussion | 20 | 11-21-2007 11:12 PM |
| How can I up my feed rate ? | ynneb | DIY-CNC Router Table Machines | 7 | 07-12-2004 09:40 PM |
