Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Machines running Mach Software
Machines running Mach Software Discuss your set-up and experiences running your machine using Mach software here.
Old 05-01-2011, 06:52 AM
rickybar is on a distinguished road
Tangential Fabric Cutter Problems
Hi
I am using Mach 3 with SheetCAM as the post-processor. I have built a fabric cutter with a tangential A-axis. Would also like to have 2 pneumatic cylinders, 1 for the knife and 1 for a pen.
I have the following 3 problems:
1) When the machine is running in a straight line along the x and y axiz, The blade (a-axis) rotates in a circles as it moves in a straight line. However, when I run one of the tutorial programs of Mach3, then this problem does not occur.
2) There is a pneumatic cylinder that controls the Z-axis of the machine. The problem is that when the blade is supposed to be in the air, it is pressed onto the material and vise versa. I have tried changing the active high and low on the Z-axis direction pin. When I do this the direction changes while jogging, but not when a program is run. (In other posts they talk about setting the Z to +200 and -200 which controls the Z height. Where does one set this?)
3)I would like to be able to run a pen and a knife. I understand that I would need a different offset for each cylinder,but how would I control which cylinder is activated and moves up and down along the Z-axis
Thanks so much
Help will greatly be appreciated
Regards
Old 05-01-2011, 07:36 AM
ger21's Avatar
Sounds like all of these may be able to be worked out in SheetCAM. I'd ask Les.
Old 05-01-2011, 09:04 AM
Hi ger21
I have already been in contact with Les and he has been a great help so far.
Just thought maybe someone else could shed some light.
Thanks alot
Cutter comp problems scottsss G-Code Programing 49 11-30-2011 10:47 PM
Cutter compensation problems Richster Mach Software (ArtSoft software) 7 07-06-2008 04:27 AM
Key seat cutter problems? Von Mikey General Metalwork Discussion 4 06-18-2008 10:03 PM
to control tangential cutter w/oscillating avengine Machines running Mach Software 0 04-20-2006 10:23 AM
Building Fabric Cutter with blade handrade CNCzone Club House 0 08-29-2005 05:30 PM
