Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Machines running Mach Software
Machines running Mach Software Discuss your set-up and experiences running your machine using Mach software here.
Old 04-18-2011, 06:04 PM
sndpntlynch is on a distinguished road
motor direction in Mach 3
I am using a rack-n-pinion drive system for the Y axis. I have two separate motors for this on on the left side and one on the right side. since the motors are mounted facing the opposite direction I need the motors to turn in opposite directions. I have been told to use two different axis controllers for this One the Y axis controller and the A axis controller. How do I get the two different motor controllers to spin the motors in the opposite direction. These motors need to do the exact same thing but spin in the opposite directions. does anyone kn ow how to do this in Mach 3. It has also been suggested that I reverse polarity in one of the motors, this is simple to do but how do I get the Y axis controller and the A axis controller to do the same motion at the same time.
Old 04-18-2011, 07:28 PM
GaryCorlew's Avatar
GaryCorlew is on a distinguished road
Go to config then down to slave axis
Old 04-18-2011, 07:48 PM
ger21's Avatar
You can reverse a motor in Config >Homing/Limits. Check the "Reverse" column. You can also reverse it by toggling the active low settings for the dir pin.
And as Gary said, you Slave them. Make sure all settings are exactly the same for both motors in motor tuning.
Old 04-24-2011, 07:10 PM
Thank you Jerry and Gary. I will do this and post to let you know the results. It is sure nice to have this form available. There are going to be many question, this is all new to me.
Need help with motor direction sndpntlynch Stepper Motors and Drives 3 02-20-2011 08:10 PM
Mach newbie changing axis direction and lowering encoder count toadjammer Mach Software (ArtSoft software) 2 12-29-2010 03:45 PM
advice on direction control for backgear to mach jking Bridgeport and Hardinge Mills 2 10-22-2009 05:20 PM
advice on direction control for backgear to mach jking Mach Mill 0 10-10-2009 05:28 PM
Motor Direction Ken Bond Phase Converters and VFD 2 11-20-2007 06:22 AM
