Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Machines running Mach Software
Machines running Mach Software Discuss your set-up and experiences running your machine using Mach software here.
Old 02-14-2011, 04:58 PM
TheProCreator is on a distinguished road
Specific Settings for Vertical Rotary Table.
I want to know if there is a setting where my rotary axis will move without stepping. What I am experiencing is that the router will move to z then a then z then a etc. Is there a way to set this so A axis will move smoothly and continuously without stepping between z coordinates? I am trying to speed up the process and many videos I have seen the A axis moves with out pausing between Z steps.
Need Help!- Specific Settings for Vertical Rotary Table. TheProCreator Machines running Mach Software 0 02-14-2011 03:22 PM
Need Help!- Rabbit/lasercut rotary settings dvdlock Laser Engraving & Cutting Machines 10 09-30-2008 02:11 PM
Specific feed speed rates for specific wood mcArch WoodWorking 2 08-18-2008 10:36 PM
Are there specific router bits for specific materials? fivefishcnc General Metal Working Machines 1 02-24-2008 07:35 AM
Haas rotary table on vertical Hitachi Seiki smoggy Haas Mills 0 05-18-2005 12:57 AM
