Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Machines running Mach Software
Machines running Mach Software Discuss your set-up and experiences running your machine using Mach software here.
Old 02-14-2011, 05:12 AM
Fozzie55 is on a distinguished road
Home button doesn't Zero DRO's
Hi
Had my machine working perfectly on an old PC with XP. Upgraded to a new PC but kept XP and have a parallel port on motherboard. Cloned the system across, everything seemed to running fine.
Jogging seemed at a different speed, a bit faster, I put that down to different output on port. I have tuned the motors again.
But, I have noticed that when I press the home button, the machine homes to the homing switches but the display doesn't reset to '0'
Any ideas please?
Old 02-14-2011, 07:53 AM
restless1 is on a distinguished road
Ok I am going to take a wild guess.....
Mach 3 right?
Get the Mach 3 manual off there website and read section 4.6.5
Page 4-10
Referencing in action ...sounds like your settings have changed
I would say more but it's hard to type this from my iPad
Oh and they have video tutorials too I believe!
Old 02-14-2011, 08:48 AM
Cheers restless
Yes Mach 3. I have the manual open and yes on 4.5.4. I will study that later.
I was just puzzled why a clone of the system would produce a different result. Am I right in thinking it is because of a faster system and maybe slightly different voltages from the parallel port?
Old 02-14-2011, 10:45 AM
ger21's Avatar
Config > Homing/Limits
Check the Auto Zero boxes.
Old 02-14-2011, 11:27 AM
Cheers Gerry, they are already checked, it's my config file from another PC. I don't know why identical cloned hard drives (same files) are behaving differently on different computers.
Old 02-15-2011, 04:51 AM
Going to do a fresh install of Mach 3 as it is a different computer. I forgot how sensitive the parallel port is and probably needs tuning.
Ebay DRO's QSPSB Benchtop Machines 3 11-22-2009 09:25 PM
DRO's Fwd She Bridgeport and Hardinge Mills 0 09-14-2008 08:31 PM
DRO's on ebay? wafarmer General Metal Working Machines 0 12-11-2006 08:29 AM
using DRO's on a CNC machine? nickydubs General Electronics Discussion 1 10-24-2006 09:28 PM
DRO's debogus Mini Lathe 3 06-26-2006 09:01 PM
