Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Machines running Mach Software
Machines running Mach Software Discuss your set-up and experiences running your machine using Mach software here.
Old 08-17-2010, 12:25 AM
maxlkauker is on a distinguished road
Mach 3 setup for Homemade router!
Hi I have been working on a homemade cnc router for some time now and i have finally got to the electronics. (Sigh) Oh wait... guess not
I Have a couple of problems so i'll list them.
1.) I don't know how to make my cnc go to home position by pressing a key.
Is there a button on screen or do i need to sync a key command?
2.) Is there a limit that I can apply for my 36x24" table? I only have a cutting surface of 20x19" and I went to the Home/Limit Tab in Mach 3 and set "Soft Max" to 20" on X, 5" on Z, and 19" on Y. I set all the "Soft Min" to 0 but it will not limit itself to those dimensions and is almost stripping out my threaded rods.
These problems are probably a very simple number or button to put in but i just can't seem to find it.
Thanks!,
~Max Kauker
Old 08-17-2010, 10:53 AM
ger21's Avatar
Do you have home switches? If so, the ref all home button will home the machine. If you don't have home switches, then what are you calling "home"
Do you have Softlimits turned on? There's a button to toggle then on/off.
Old 08-18-2010, 12:27 AM
I got the homing system down but now I just need to know how to configure mach 3 to my router TABLE. Is there a spot that I can say how large my table is and how far it should move without hitting the sides? I am trying to adjust soft limits but i don't know what numbers to put in.
Here are the pictures of the soft limits and what i have them set to. The numbers that i put in are all the maximum inches of travel the system can do without hitting the side.
Old 02-18-2011, 11:47 PM
agguilar is on a distinguished road
HELP PLEASE
i have the same problem i have a machine and dount know how to set it up please help,,, any one,,, HELP!!!!!!!!!!!!!!!!
Tags
mach 3, problem, table setup
New Machine Build- My diy homemade router cnc-microcut DIY-CNC Router Table Machines 18 04-27-2009 06:51 AM
mach 2, xylotex and homemade digitizing probe gun_mike Benchtop Machines 9 03-16-2008 08:50 PM
Here is my new homemade router ahmed CNC Wood Router Project Log 8 12-09-2006 12:17 PM
Another Homemade CNC Router southernexplore DIY-CNC Router Table Machines 0 02-18-2006 08:59 PM
And yet another first homemade router Stevenpats DIY-CNC Router Table Machines 1 11-15-2003 05:28 PM
