Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Machines running Mach Software
Machines running Mach Software Discuss your set-up and experiences running your machine using Mach software here.
Old 08-09-2010, 07:53 PM
Bob La Londe is on a distinguished road
Radius to end of Arc Differs From Radius to Startline
Ok... Why? I mean I used this G-code file to cut an actual work piece under my previous profile. However under the Gecko XML I get this error.
What setting would be different that the code would be good in one, but not the other?
I reloaded my old profile and loaded the same g-code file just to make sure and it did not stop at this as an error.
Bob La Londe ~ Owner of two and a quarter G540s.
www.YumaBassMan.com
Old 08-09-2010, 08:58 PM
Sorry if I posted that in the wrong area, but since it was related to a Gecko Drive change and XML file... oh nevermind. Just glad its where you want it now.
www.YumaBassMan.com
Old 08-09-2010, 09:16 PM
ger21's Avatar
It's a Mach3 issue, not a Gecko issue, so I moved it to the Mach3 forum.
As you saw in the Mach forum, it's probably due to the IJ mode. Change it in General Config.
"Radius to end of arc differs from radius to start on Line #" labuda G-Code Programing 8 11-15-2009 06:35 AM
Need Help!- Radius to end of arc differs from radius to start? Jamy LinuxCNC (formerly EMC2) 2 08-22-2009 11:28 PM
Problem- radius help Scott Halstead GibbsCAM 0 06-12-2008 07:27 AM
"Radius to end of arc differs" problems ! Geetar-ist G-Code Programing 7 12-16-2007 12:22 PM
Zero Radius Arc Xular Mach Mill 4 12-13-2006 09:10 PM
