Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Machines running Mach Software
Machines running Mach Software Discuss your set-up and experiences running your machine using Mach software here.
Old 07-19-2010, 04:40 PM
Richotech is on a distinguished road
LPT pins 16 and 17 problems using
Hello,
I am using a new controller board that uses pin 16 to enable (enable 1) the steppers for axis control and pin 17 to run a relay (output 1)for the spindle. The problem is they seem to affect each other and when I set them up as stated above they turn the other on/off and if I can start the spindle it wont turn off whether by g-code or manual in mach 3. Anyone got ideas ?. If the LPT port is the problem I think I might be in trouble.
Cheers,
Brett.
Popup pins Adam M. Work Fixtures and Hold-Down Solutions 0 01-15-2008 08:43 PM
Runing out of pins? bigz1 Hobbycnc (Products) 28 05-19-2007 06:17 PM
More on ports and pins andrewbishop66 Mach Software (ArtSoft software) 2 03-08-2007 07:05 PM
Dowel Pins Ursine DIY-CNC Router Table Machines 2 05-27-2005 07:53 AM
Dowel Pins Mr.Chips General Metalwork Discussion 13 02-01-2004 04:00 PM
