Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Machines running Mach Software
Machines running Mach Software Discuss your set-up and experiences running your machine using Mach software here.
Old 07-07-2010, 05:56 PM
Rico55 is on a distinguished road
Run From Here?
Every once in a while, my machine will stop in the middle of a cut. I think it might be static electricity or just a gremlin, but I haven't quite figured out how to get the program to run from the line that it stopped on. If I click on "run from here", the program will cycle back from the beginning to the line that it stopped on, and then a preparatory move box will pop up- even though the numbers in the preparatory move look right according to the program, the Z axis will dive straight down, past the number that was shown in the box. What causes this, and what is the solution?
Old 07-07-2010, 06:15 PM
jhowelb is an unknown quantity at this point
Be sure to set up "Safe Z Movement" dialog in the config menu.
The number in the "box" you refer to is the Z position for the impending move.
I also like to reference home to zeros while starting a program just to avoid a few more adventures.
After all that, it should take u right where expected.
"Error of Opinion may be tolerated where Reason is left free to combat it." - Thomas Jefferson
Old 12-27-2010, 11:02 PM
Captain Midnigh is on a distinguished road
"run from here" only works with lisenced copies of software.
Old 12-28-2010, 09:54 AM
Starleper1 is on a distinguished road
When that preparatory move dialog box pops up just click cancel and then cycle start and it will run from that line.
I'm not sure if it's a bug, but that's how I've always used it. Just make sure that the reason your machine stopped isn't due to a stepper stall or your position won't be where you expect it to be.
Old 01-10-2011, 11:27 AM
cjdavis618 is on a distinguished road
Mine will occasionaly do the same thing thinking a limit switch has been triggered (Unsheilded wire at present, shielded on the way). But when I reset the trigger, and hit start, the machine will screw up the part. Last time, it went hard to the X+ ruined a $30 long endmill.
So if that happens again with limit switch trigger or broken it. I should be able to reset, home all axis, then do the "Run from here to start the process a line right before before it triggered. Will that allow me to finish the cut without problems?
Obviously, I would have my offsets in the program already, so the locations of cut should stay the same. And if there was tool breakage or something, this should allow me to get back to the right locations for cut once new tool is set and zeroed to part.
