Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Machines running Mach Software
Machines running Mach Software Discuss your set-up and experiences running your machine using Mach software here.
Old 06-21-2010, 09:36 PM
Richotech is on a distinguished road
Problem moving steppers with keyboard buttons
Hello,
I have been using Mach3 with my small homemade engraving machine and many times when using the keyboard buttons to control the stepper motors it just stops working, yet if I press the TAB key to use the on screen buttons with mouse they do move them every time. Anyone have any reasons for this. It seems like the pulses aren't being sent when they should while using the keyboard.
Cheers,
Brett.
Old 06-21-2010, 10:03 PM
ger21's Avatar
Do they move at all with the keyboard? If so, do they just stop, or do the motors stall and make noise?
Old 06-21-2010, 10:39 PM
Hi Gerry,
Thanks for helping. They just stop, but are still energized. They work using the on-screen jog with the TAB key. There is no noise or disruption when using the keyboard.
Brett.
Old 06-22-2010, 10:55 AM
ger21's Avatar
Old 06-22-2010, 11:19 AM
M250cnc's Avatar
M250cnc is on a distinguished road
Brett
Check you have jogging enabled Ctr-Alt-J on standard mill screen
Phil
Need Help!- My steppers are not moving. Crawler374 Mach Software (ArtSoft software) 10 09-13-2009 01:31 PM
Keyboard Arrows Problem kolias DIY-CNC Router Table Machines 10 08-15-2009 04:31 PM
Need Help!- G540 problem, steppers not moving CS900 Gecko Drives 36 11-13-2008 10:38 AM
Mini Keyboard Problem? Willyb Tormach PCNC 9 09-23-2007 05:00 PM
Keyboard problem BeliVolk General Electronics Discussion 2 07-10-2007 01:00 PM
