Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Machines running Mach Software
Machines running Mach Software Discuss your set-up and experiences running your machine using Mach software here.
Old 04-20-2010, 01:15 PM
Gold Member
heilcnc is on a distinguished road
c6 speed control board
has anyone got good speed control using this the c6 board i am using mine with a c10 breakout board plus a kbic 240ds board hooked up to the dc motor on a cnced 7x12 lathe that has a 1 slot pick up sensor for threading that this lathe has done very good before i tried to control the speed i loaded the last lockout ver of mach3 turn once i ran the calibrate spindle i can not get good rpm readings say i command m3 s1000
dro reads s1459-1333 worked much better before i added c6 step and direction board only varied 1 to 3 rmp from command does the spindle calibration work?
C6 SPEED CONTROL BOARD heilcnc Mini Lathe 4 03-16-2010 07:38 PM
CNC4PC Variable Speed Control Board Bubba TurboCNC 10 08-07-2009 10:01 AM
Need Help!- Connecting a breakout board to spindle speed control waisberg Commercial CNC Wood Routers 1 07-13-2009 06:37 PM
Need Help!- breakout board with spindle speed control 6bx General Electronics Discussion 6 02-19-2009 01:35 PM
Need Help!- Seig x2 Speed Control and c6 Control Board skmetal7 Benchtop Machines 2 04-21-2008 03:17 PM
