Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Machines running Mach Software
Machines running Mach Software Discuss your set-up and experiences running your machine using Mach software here.
Old 03-16-2010, 02:22 PM
RobH is on a distinguished road
Accuracy in pocketing.
Hello,
I am having a problem with milling using Mach 3. The finished part is consistenly under size (about .5mm in 35mm). I use Lazy Cam to generate the G-code.
I have tried all the obvious culprits, backlash in leadscrews, Tool sizes in tools, and have checked axis movement with a DTI against DRO in the program and all are OK. The round pockets a perfectly round which seems to eliminate any suggestion of a backlash problem. Could there be a problem with the software?. I have tried the backlash setting both on and off with the same result. The error is consistant and I can fiddle the dimensions to get the sizes I want but would like to be able to get predictable results.
Any help gratefully recieved.
Rob
Old 03-16-2010, 04:15 PM
BobWarfield's Avatar
BobWarfield is on a distinguished road
How certain are you that the endmill is actually the advertised size?
I had some inexpensive but good endmills I got off eBay. They were name brand, but I discovered they were pretty far off in terms of diameter. I don't think they were as bad as 0.5mm, but by the time you are off on both sides of the pocket, maybe so.
I wound up measuring test cuts to see what the actual diameter was.
The other culprit to consider is tool deflection. Are you doing a very light finish pass? If you run it again does it still cut chips?
Best,
BW
Try G-Wizard Machinist's Calculator for free:
http://www.cnccookbook.com/CCGWizard.html
Old 03-16-2010, 04:54 PM
fatal-exception's Avatar
fatal-exception is on a distinguished road
Is there a 'finishing allowance' setting in Lazy CAM? If its on, it will leave a specified amount of material for taking off with a finish path. I would check for that.
Paul
Old 03-16-2010, 04:57 PM
Hello Bob,
Thanks forthe reply, I have just measured the mills, I tried two, They seem spot on. (They are Dormer SKF).
I will check the tool deflection although I had the same result in plywood.
Rob.
Old 03-16-2010, 06:13 PM
TDA TDA is offline
TDA is on a distinguished road
Are you climb cutting? I've never heard of it causing that much of a mismatch but you might want to try a conventional cut cleanup pass.
John Torrez
Think & Tinker / PreciseBits
Old 03-16-2010, 06:41 PM
No I am not climb milling, I will try the cleanup pass. Thanks.
pocketing signIT DIY-CNC Router Table Machines 7 06-06-2006 09:04 AM
Pocketing CNCadmin GRZ Software- MeshCAM 5 05-11-2006 08:44 PM
Pocketing dneisler BobCad-Cam 4 12-18-2005 10:57 PM
Accuracy determination & accuracy improvement rweatherly DIY-CNC Router Table Machines 5 08-11-2005 08:37 AM
Accuracy problem with pocketing CNCadmin Yeager Automation 3 10-04-2004 11:23 PM
