Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Machines running Mach Software
Machines running Mach Software Discuss your set-up and experiences running your machine using Mach software here.
Old 03-16-2010, 10:22 AM
Marty_Escarcega is on a distinguished road
Mach III and Metric Ballscrews
I am in the research mode. I am going to convert a Clausing 12"x24" lathe to CNC. Among the things I am researching, I see several vendors on eBay selling metric ball screws at what seem to be a good price. (I'm torn between the rolled metric ball screws and precision ACME screws and nuts at this point) Anyway can Mach II take the 5mm leadscrew pitch and still run run in the imperial mode?
Thanks in advance
Marty
Old 03-16-2010, 10:26 AM
Crevice Reamer's Avatar
Crevice Reamer is on a distinguished road
Thanks in advance
Marty
The answer is yes. You set units to inch, but steps per inch will be somewhat different than inch screws, because of metric pitch.
For example:
My SX3 uses metric ball screws. 200 * 10 * 5 TPI should be 10,000 steps per inch. But because the metric screw pitch is slightly different, SPI is more like 10,251.
CR.
http://crevicereamer.com
Too many PMs. Email me to my name plus At A O L dot com.
Old 03-17-2010, 06:39 PM
Claude Boudreau is on a distinguished road
Wink inch and mm
Reading this tread ,on same forum, might help,
Need Help!- different lead on x and y
Claude Boudreau
Old 03-20-2010, 08:24 PM
For example:
CR.
How do you calculate that? I am looking at this setup from a dealer on eBay:
http://cgi.ebay.com/2-antibacklash-b...item3a51b09aa9
Marty
Old 03-21-2010, 08:29 AM
Marty
You can either use the tedious set and try method, or Mach3 will calibrate it for you:
CR.
How to confire Mach 3 (metric) when my ballscrew 1 inch pitch ? Calico Machines running Mach Software 8 12-22-2008 07:24 AM
Problem- I need a metric nut and I need help on where to get one ryansuperbee Want To Buy...Need help! 11 11-27-2008 01:54 PM
Used ballscrews quant Linear and Rotary Motion 6 06-23-2007 10:20 AM
Confused: Mach Turn, Mach Mill, Mach 2/3 ? CanSir Mach Software (ArtSoft software) 5 02-16-2007 04:41 AM
Mach 3 Wizards- Metric mm possible ? ASlater General Metal Working Machines 1 12-12-2006 07:25 AM
