Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Machines running Mach Software
Machines running Mach Software Discuss your set-up and experiences running your machine using Mach software here.
Old 03-10-2010, 11:56 AM
Mkroe is on a distinguished road
RF problem with limit switch and estop
Hi All,
This may have been discussed before not sure couldn't find it here using search.
I have been plagued with RF spikes triggering my limit switch and Estop. Tried the debounce to no avail. Using well shielded cables did not improve this either.
I live in an area where I am in the flight path of a major airport, It may be the planes radio causing this? No Matter though
After scoping this, we saw unusual spikes that were giving phantom triggers.
Solution is easy and cheap.
Using a 0.1 Uf /mfd film type capacitor , NOT ELECTROLYTIC
Bridge each set of wires at your breakout board with a cap. One lead to ground the other to +V.
This will act as an Rf filter and should eliminate the problem. You may need to add a second one parallel to this but most likely not.
I have since run a few million lines of code and no hiccups since this modification.
Just an FYI if your having this problem.
MK
Old 03-18-2010, 02:02 PM
AH HA! I found my Phantom RF spike. I was getting a static discharge from the vacuum hose when it touched the frame usually somewhere in mid table area. The hose may touch the upper gantry at various stages of XYZ location. The ground wire was broken for this hose.
I'll leave the caps on though.
Mike
Limit switch problem paulb DIY-CNC Router Table Machines 5 07-13-2009 05:49 PM
Estop & Limit Switch Setup? Regnar Xylotex 14 01-06-2009 02:31 PM
Limit switch problem? Bill Gillen AjaxCNC Control Products 2 05-08-2008 12:02 PM
Limit switch problem jimini Mach Software (ArtSoft software) 5 09-17-2007 08:49 PM
Problem With IH Limit Switch. Willyb Industrial Hobbies (Support forum) 5 11-06-2005 05:17 PM
