Need Help! Huangyang VFD YM-800A inverter - USB mach3 control board
Results 1 to 3 of 3
Thread: Huangyang VFD YM-800A inverter - USB mach3 control board
    Feb 2017
    Argentina
    Default Huangyang VFD YM-800A inverter - USB mach3 control board
    I need to connect the Huangyang VFD YM-800A inverter to a USB mach3 control board.
    Thanks in advance !!
    Attached Thumbnails Attached Thumbnails Huangyang VFD YM-800A inverter - USB mach3 control board-vfd-control-circuit-terminals-jpg   Huangyang VFD YM-800A inverter - USB mach3 control board-conexion-vfd-placa-jpg   Huangyang VFD YM-800A inverter - USB mach3 control board-usb-control-board-wiring-diagram-jpg
    Apr 2013
    Sweden
    Default Re: Huangyang VFD YM-800A inverter - USB mach3 control board
    OK, so what is the question? Did you try anything? Did you wire it up as the manual shows?
    https://www.youtube.com/c/AdaptingCamera/videos
    https://adapting-camera.blogspot.com
    Feb 2017
    Argentina
    I connected it according to the control board diagram but it didn't work. The inverter in the control board diagram is not the same as the Huangyang VFD YM-800 inverter and I can't find out how to connect them. Please, help me.
