Need Help! Chinese 6040 running Mach3
Results 1 to 2 of 2
Thread: Need Help! Chinese 6040 running Mach3
    Jan 2017
    Exclamation Need Help! Chinese 6040 running Mach3
    Ok after a week of getting info I was able to get the correct settings to run my chinese 6040 with mach3 , and was able to cut a part out of aluminum with no problem, so the next day I opt to install a wired xbox controller and install the xbox30 control plugin, I couldnt get it working right, but after that the machine will not respond at all, so i uninstalled the mach3 and deleted the mach3 folder and reinstalled it and setup all the settings as before when it would run and it still does not respond when I try to jog the machine. anyone have any Ideas????
    Aug 2017
    Default Re: Need Help! Chinese 6040 running Mach3
    Hi there Im a newbie and bought a 800w water cooled spindle
    Cnc6040z USB machine
    Need help Mach3????? I need to know which
    mach3 I need to download from download
    page as there is a couple of them,
    for my dell laptop
    d620 laptop running Win7 pro 32bit and then I
    Need to know how to set it up complete to
    getting the machine axis to move quickly and
    smoothly ? im stuck please help
