Results 1 to 4 of 4
Thread: Makino A61 with fanuc 31i pro5
    Apr 2012
    spain
    Hello I would like to get a manual for programing macros.
    I have got the original fanuc manuals, but It does not explain very well How I have to develop the custom macros.
    I have been looking at the forums and I have seen the book Fanuc CNC custom macros.
    Is it what do I need?
    Someone knows anything better.
    I have to develop many custom macros for manufacturing.
    I will be very glad to hearing from you.
    Thank you in advance.
    Best regards.
    Feb 2006
    Mexico
    Having the manual does not seem like your problem
    I have the programming manual too and it seems to explain how to do a macros. What I think that you need is the PMC programming manual, which explains how to map PMC data to the CNC program...am I right?
    I have that too, PM me your email address and I will mail it to you.
    Apr 2012
    spain
    Thanks for the help.
    Thanks for answering.
    As you say I have got all fanuc manuals and makino manuals.
    I am trying to make custom macros to makino.
    One of my questions is How could I find out the signals that I have to use in the macro program?
    For instance, I have been looking for in the manuals the meaning from the macro #535 and I could not find out.
    Where could I find out which is the meaning of #535 and also others of them.
    Browsing by internet I find out the meaning of #535, but sometimes I can not understand it
    I have been reading a custom macro program about the tool life and I do not know the meaning of M102S1
    Which is meaning of M102S1 at the custom macro ?
    I will be glad to hearing back from you.
    Thanks in advance.
    Feb 2006
    Mexico
    #535 is a common variable. Common variables are MACRO program variables which the user assigns a given value for later use. Go to the MACRO menu by pressing OFFSET/SETTING and then press + and select MACRO. You will see all the variables and their values. If, for example, you asign a value of 1.5 to your variable #535 you will see on this menu that you have a 1.5 on the #535 variable.
    This 1.5 you can later use to program something like this
    G01F#535
    and it will be equivalent to writing
    G01F1.5
    because the current value of variable #535 is 1.5
    You can access most of the data available on the NC to use on a program by using variables.
    About your other question, the M102S1 can mean anything if taken out of context. Can you post the rest of the MACRO? M102 seems to be a machine code (like M08 or M06) and S1 looks like programming for spindle speed...but I cant be sure unless I look at the rest of the program.
  1. Hypermill post for Makino Pro5 control
    By skykash2000 in forum Post Processor Files
    Last Post: 04-16-2009, 07:34 AM
  2. Post For Makino Pro5
    By skykash2000 in forum General CNC (Mill and Lathe) Control Software (NC)
    Last Post: 04-15-2009, 11:01 AM
  3. Need Help!- Makino A-55 with fanuc 0m?
    By ALAUDY in forum Fanuc
    Last Post: 05-03-2008, 10:42 AM
  4. Makino MC-86 W/ 11M Fanuc PMC
    By mcrosby in forum CNC Machining Centers
    Last Post: 06-04-2007, 06:12 PM
  5. Makino Fanuc 0-MC
    By DHYSTA in forum Fanuc
    Last Post: 04-07-2007, 08:38 AM
