| Machinery Manuals & Brochures Post Machinery Manuals & Brochures here! |
There are some very old posts on this lathe, however I've purchased one and it seems nobody is still around from the posts. I was hoping to use the unit as is. I plan to use an old windows 95 ... or older comp to run the software. Any information or help on it would be greatly appreciated. I don't have any manuals, I did find a post with the pinouts(serial connector) . The unit is 90's vintage and looks like new. |
I think we have something in common. I have a Phoenix wood lathe that I want to get online. I had the software on a floppy at some point-cant find it now. Like you said, there is very little info to be found about those. I have the books on the lathe itself and for programming. I just need the software! I can help you with the books-maybe scan into a PDF. Can you help, or can you point me in the right direction? I am going to run production on mine. Drill and turn an abrasive foam composite that is part of a groundwater leeching pump. Need to hold +/-.005 dia over 20 inches, and hold .01 on length. |
I dont have the origional software for the lathe, but I did locate the software for the router, which may be quite simular. I haven't had a chance to really check it out. I did locate a post in which the person used Umbuntu Linux and EMC2 software. Umbuntu can be loaded on any computer, will set up a second operating systme which you can boot to. The EMC2 software and unbuntu are free to use and what I have heard it is a good way to go.. The link for the website for the EMC2 download is KCam, EMC2, Mach3, TurboCNC,and other CNC related software links. I am preparing to move the lathe into my basement and then will try getting it up and running. A manual would be great. |
I would think the router software is very similar. This is what I would if I could-I already have all the documentation for the original software. I will be back in CA in the next week or two. I will make an index of the info available to me, and then you can tell me what you need. I can scan pages into a PDF to email you. My lathe has what appears to be a parallel cable, and an irregular power connector. Maybe 220 single phase or ?. If you can, please send me the original. Thanks, Scott |
Attached is the phoenix router dos software. I don't have a computer with a systme for running dos programs.(win 98 or older) An individual did suggest using DosBox (downloadable program, freeware) DOSBox, an x86 emulator with DOS |
Thank you very much for the effort to get me that program. I am gonna take a look at it and see where I am at. I will get you all documentation on that thing I can. Will be at least a week before I have work again in California. I would go get the info for you anyways, but I am 200+ miles away. Would you please keep your eyes out for the actual lathe software?? Did you say that you don't have it, or that you don't have the install file? Any and all info is appreciated! Scott |
You may want to compare this software to the manuals. It is a dos based lathe program about the right vintage and the name is close. E Z CNC is an old software hope its right, bob |
#10
I appreciate that you are still trying to find that software for me. You are the one that needs the manual, right? I am in CA and might be able to do something about that this week. Scott |
| Need Help!- Magnum Phoenix GS CNC router | jeffmorris | Commercial CNC Wood Routers | 10 | 05-01-2012 11:33 AM |
| Need Help!- NC software for Magnum Phoenix GS router? | jeffmorris | General CNC (Mill and Lathe) Control Software (NC) | 0 | 04-02-2011 08:18 PM |
| Need Help!- Setting up Magnum Phoenix Gs-512 CNC Router | enlightage | Machine Problems, Solutions , Wireless DNC, serial port | 0 | 03-02-2011 06:32 PM |
| Help with Phoenix cnc wood lathe specs | Carver | CNC Machining Centers | 0 | 09-29-2003 09:31 AM |
