we come from thailand, the fpc manufacture,we are looking for a machine which can drill the hold and cutting on FPC board, what is the quality guarantee. and cost ,delivery time?any details we can check .if there have video ?thanks
◆ High-performance UV Laser Source: UV Laser is a diode pumped laser source with high beam quality, high peak
power, short pulse duration and stable high power pulse, which is a "cold" process that ensures the stability of
cutting quality.
◆ Optimized Optical System: This system ensures processing accuracy with lower power consumption, smaller spot
size, higher beam quality, and supports autofocus function.
◆ Control System: High resolution linear gauge ensures the location
accuracy and repeatability
.◆ Natural Granite Platform: Natural and massive granite base reduces the inertia vibration of the table during start-up,
shut-down and acceleration. At the same time, it maintains temperature stability.
◆ Air Bearing Design: Air bearings are used due to their high precision, long-term stability, frictionless motion and easy
maintenance.
◆ Software: smart laser micromachining application platform, that is user-friendly, and supports most
industrial data formats.
◆ Drilling and de-panelizing flexible printed circuit board, rigid printed circuit board, flexible-rigid printed circuit board, and
chip substrate package.
◆ De-panelizing assembled flexible or rigid circuits.
◆ Precisely cutting and scribing ceramics with the thickness within 2.0mm.
◆ Precisely cutting thin copper foil, pressure sensitive adhesive, PP, acrylic sheet, polyimide film, etc.
◆ Precisely cutting ITO thin film, glass, organic thin film, special metal sheet, wafer and sapphire, etc.
◆ Support Roll to Roll Cutting way
always provide the good resolution of laser cutting,laser marking,laser welding equipment for you. www.hanzlaser.com MSN: zgzg1125@hotmail.com Skype:lisaseekcn
thanks for your information,i link to your website of Hanzlasercn's Channel - YouTube ) for the machine operation.
we will send you the details .
