- Need Help!- Toyokoki APB-286 Help Needed.
I am working on a Toyokoki APB-286 press brake that had a controller problem after a power surge. I was able to reset the controller and the back gages but the ram movement is extremely slow. I expect the reset procedure erased some if not all machine control parameters. Unfortunately I have not been able to find any reference to correct this issue. I am hoping someone on this forum might have a manual or some documentation listing the parameters for this machine. Any help would be much appreciated
Re: Toyokoki APB-286 Help Needed.
Did you find a manual or parameters?
No not yet. The machine is now off line and no longer used for production. We use it for occasional work but I have yet to figure out how to return the ram to the speed it was before. This brake is very hard to find info on..
- You may not post replies
- You may not edit your posts
Forum Rules
